10-07-2022 12:55 AM
hello
we have two nexus 9138 switches that are connected to servers using VPC configuration when I preferred to upgrade for one of them the servers indicated the interfaces went down and no network connection appears while the second switch is up . this scenario not appear when we disconnect one of interfaces in swithces since the VPC with servers is up from second one so please we need advise for that
Bests
10-07-2022 02:25 AM
check the server NIC teaming.
10-08-2022 03:58 AM
thnx for reply , the nic team look fine since when disconnect one of interface the process working fine
10-08-2022 01:49 PM
Understand the sequence is so important to understand the problem and how we can solve it,
from cisco doc. about auto-recovery,
""Since vPC peer-keepalive is still on, it detects dual-active detection. The vPC secondary S2 turns off all its local vPCs.""
this normal vPC behave where when the VPC peer-link is down but the peer-keepalive is still ON, in this case the secondary is tunr off ALL its local vPC and hence you loss connectivity to Server.
https://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-series-switches/116187-configure-vpc-00.html
please read the Doc. and confirm that this what you face.
