Power Cord Compatibility
viraj patil
I just wanted to check that in Malaysia, the AIR-CT5508-K9 wireless controller is being replaced by the C9800-L-F-K9 model. Can the power cord from the 5508 controller be used with the 9800 controller?
 At the same Malaysia location, we are also replacing the WS-C4500X-40X-ES and WS-C4500X-24X-ES switches with C9500-48Y4C-A switches. So, can we also use the 4500X switch's power cord with the 9500 switch?
Mark Elsen
  - The power cords will not be compatible , use the power cord(s) delivered with the product that you ordered ,
 M.
