Power Cycle 6509
aloisgeorge
I just changed the way I log into a 6500..creating a username and password and then enabling login local on all lines including the console!(Fortunately I dint save the config) Somehow I can no longer log into my switch and I want to power cycle the switch to undo the changes. The set up is not redundant and bringing down the switch would have undesirable consiquences.
Is there a way I can reload config with minimal disruption to teh organazation? If I where to reset the switch on average how long would it take to get back to normal running state? do I need to do anything 'special' before pulling out power supplies?
I am running one Supervisor engine in Slot 6, can I just pull it out and back in to reload config?
Help would be most appreciated, thanx.
6 Replies 6
Giuseppe Larosa
Hello George,
roughly 5 minutes are needed to perform a reload
I would go in this way.
Hope to help
Giuseppe
Thank you..do I just switch power off and then on?
Rgds
That would work but you should also have the console already connected so you can watch for any errors while the switch powers back up.
Hello George,
yes power off and then power on
a console connection can be a good idea ..
Hope to help
Giuseppe
Leo Laohoo
Hello Leo,
the original poster George is not able to access the device after having introduced local authentication so a power cycle is needed to rollback to last saved configuration.
Anyway, this warm reload feature looks like interesting.
Hope to help
Giuseppe
