How to monitor activity /usage on the switch
UCBNOCWAN
how to monitor the activity of the switch, or how to identify which connections are remained inactive for long time
sample out puts is pasted below
Interface Status Description Last Used
FastEthernet0/3 down 0z222 4w2d,
FastEthernet0/4 down 1z144 1w2d,
FastEthernet0/6 down 1z192 1d06h,
Please let me know whats the command used to get the above output
regds
KSK
9 Replies 9
adamclarkuk_2
Level 4
Level 4
Try show interfaces status inactive
hi
i dont think so its the correct one
regds
KSK
What switch are you on ?
glen.grant
If it is a 4500 then it's "show int link " . They are really the only ones that will easily give you that information . Wish they would include that command on all models , it seems to be a highly requested feature .
The model of Switch is cisco WS-C2950G-48-EI
regds
KSK
Thanks for that little gem, I have to look after 50 x 4506/4510's and that will come in handy. Just for info, it also works on 4948's.
Correct it would work on the 4948's because they run the same exact code as the 4500's .
Nice little gem this one. Works on a ME-4924-10GE too.
Leo Laohoo
Have you tried using Solarwinds' Network Engineer's Toolset? Using SNMP, one of the applications, Real Time Interface Monitor, will do exactly what you are looking for.
