Power Inline Bug?
Andrew Clark
Level 2
Level 2
Switch: WS-C2960X-48FPS-L
IOS Version: 15.0(2)EX5
Problem Details: Receiving an inline power message %ILPOWER-5-POWER_GRANTED and %ILPOWER-5-IEEE_DISCONNECT for every second of every minute however there is nothing plugged in to the port that is doing this.
Is this a bug or something else? As i've stated. Nothing is plugged in to this port. For now i have done a "power inline never" because it was filling up the logs.
Rajeev Sharma
Hey,
Post the show run command command output from this switch.
RS.
sh run
Building configuration...
Current configuration : 27334 bytes
version 15.0
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname  (omitted)
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
switch 1 provision ws-c2960x-48fps-l
switch 2 provision ws-c2960x-48fps-l
ip domain-name  (omitted)
mls qos map policed-dscp  0 10 18 24 46 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
spanning-tree mode pvst
vlan internal allocation policy ascending
class-map match-all AUTOQOS_VOIP_DATA_CLASS
  match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
  match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
  match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
 class AUTOQOS_VOIP_DATA_CLASS
   set dscp ef
  police 128000 8000 exceed-action policed-dscp-transmit
 class AUTOQOS_VOIP_SIGNAL_CLASS
   set dscp cs3
  police 32000 8000 exceed-action policed-dscp-transmit
 class AUTOQOS_DEFAULT_CLASS
   set dscp default
  police 10000000 8000 exceed-action policed-dscp-transmit
interface Port-channel1
 description ***Port Channel to IDF1***
 switchport mode trunk
interface Port-channel2
 description ***Port Channel to IDF2***
interface Port-channel3
 description ***Port Channel to IDF3***
interface FastEthernet0
 no ip address
 shutdown
interface GigabitEthernet1/0/1
 description ***Trunked Link to Router G0/0***
 mls qos trust dscp
interface GigabitEthernet1/0/2
 description ***Uplink to ASA Inside Interface Port 1***
 switchport access vlan 21
 switchport mode access
interface GigabitEthernet1/0/3
 description ***Uplink to ASA Outside Interface Port 0***
interface GigabitEthernet1/0/4
 description ***Uplink to ASA POS-Gateway Interface Port 2***
 switchport access vlan 22
interface GigabitEthernet1/0/5
 description ***Netgate vlan 1 Port 1***
interface GigabitEthernet1/0/6
 description ***Netgate vlan 22, 111 Port 2***
 switchport trunk allowed vlan 22,111
 shutdown
interface GigabitEthernet1/0/7
 description ***Aerohive AP***
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
 description ***POS VLAN***
 spanning-tree portfast
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
 description ***Data VLAN***
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
 description ***Trane BCU***
 speed 100
 duplex full
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
 description ***Trunk Link to IDF1 Port Channel 1***
 mls qos trust dscp
 channel-group 1 mode active
interface GigabitEthernet1/0/50
 description ***Trunk Link to IDF2 Port Channel 2***
 mls qos trust dscp
 channel-group 2 mode active
interface GigabitEthernet1/0/51
 description ***Trunk Link to IDF3 Port Channel 3***
 mls qos trust dscp
 channel-group 3 mode active
interface GigabitEthernet1/0/52
interface GigabitEthernet2/0/1
 description ***VOICE VLAN***
 switchport voice vlan 8
 power inline auto max 15400
 srr-queue bandwidth share 1 30 35 5
 priority-queue out
 mls qos trust device cisco-phone
 mls qos trust cos
 auto qos voip cisco-phone
 service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
interface GigabitEthernet2/0/2
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/3
 description ***Data/Phone***
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/4
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/5
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/6
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/7
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/8
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/9
 power inline never
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/10
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/11
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/12
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/13
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/14
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/15
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/16
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/17
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/18
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/19
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/20
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/21
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/22
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/23
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/24
 priority-queue out
 mls qos trust cos
interface GigabitEthernet2/0/25
 description ***Camera VLAN***
 switchport access vlan 23
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
 description ***MDF UPS***
 switchport access vlan 111
 power inline never
interface GigabitEthernet2/0/49
 mls qos trust dscp
interface GigabitEthernet2/0/50
 mls qos trust dscp
interface GigabitEthernet2/0/51
 mls qos trust dscp
interface GigabitEthernet2/0/52
interface Vlan1
 no ip address
 shutdown
interface Vlan111
 ip address  (omitted)
ip default-gateway  (omitted)
ip http server
ip http authentication local
ip http secure-server
line con 0
line vty 0 4
 password 7 114A2D0C14191F03072161
 accounting commands 1 cmds1
 accounting commands 15 cmds15
 transport input ssh
line vty 5 15
 transport input ssh
ntp server (omitted)
end
Hey,
I thought there may be some macro which you have enabled causing this but configuration seems clean so I suggest opening a TAC case for this as you mentioned nothing is connected to this port and yet switch was throwing PoE syslogs.
HTH.
RS.
