VSS- Getting Out Of Recovery Mode
Robert Ho
hey all, not sure if this is normal behavior.
2 chassis each with dup vss sup engines
chassis 1 active, chassis 2 standby
basically, we pull the active sup out of the chassis 1, chassis 1 reboots, chassis 2 takes over, but when chassis 1 comes up with the other sup (in slot 6), it comes back in recovery mode. is this normal? how do we get it to boot and become standby?
Core-VSS(recovery-mode)>en
Core-VSS(recovery-mode)#
Core-VSS(recovery-mode)#sh switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 10
Local switch number          : 1
Local switch operational role: Virtual Switch Active
5 Replies 5
Reza Sharifi
No, that is not normal.  When chassis 1 comes back online, Sup in slot 6 should  be in SSO hot standby state.
Before any failure and when both chasses are online.  The first Sup in switch 1 is in SSO active and the second Sup in switch 1 is in RPR-Warm.
The first Sup in chassis 2 is in SSO Hot Standby and the second Sup in RPR-Warm.
Reza
hi, what do you think could be the problem?
now, we inserted the sup back in slot 5, rebooted the whole chassis, and it defaulted back to non-vss.
we are at a lost. any help is appreciated, thanks!
What version of IOS are you running?
s72033-advipservicesk9_wan-mz.122-33.SXI5.bin
should we upgrade? it has been very difficult to bring this standby chassis back to vss.
we did a "wr e" and as soon as we convert to vss mode and add the fast-hello links and 10ge vsl's, it goes to recovery mode?
I guess you dont met the requirements to perform a Quad Supervisor SSO (VS4O)
Follow note from Cisco site.
VS4O is available for the Cisco Catalyst® 6500 Virtual Switching System configured with the Cisco Catalyst 6500 Series Supervisor Engine 2T beginning with Cisco IOS® Software Release 15.1(1)SY1
