Power inline port 2x-mode command for 9200L? PoE problem
WM99
Currently using this command power inline port 2x-mode on a 2960x switches to fix the PoE problem for some of PoE devices that suddenly draws more power when activated at random intervals. However just replaced a 2960x switch with a 9200L switch and the command seems to have went through but doesn't fix the PoE problem anymore. Was looking to see if anyone had a solution to a similar problem on a 9200L?
balaji.bandi
you can try config  :
power inline port priority high
power inline static max 15400
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/16-9/configuration_guide/int_hw/b_169_int_and_hw_9200_cg/configuring_poe.html
BB
Hi  @balaji.bandi  sadly tried even  power inline static max 30000 but still wouldn't work. This device draws a large amount of power when it gets activated but within 15.4w. On the 2960x I had the same problem but found some users using the command  power inline port 2x-mode and it fixed the problem. But now we have a newer switch and that command is no longer working for it.
never used that option, you can try below options ? what is this device what kind of power required ?
(config-if)#power inline ?
auto Automatically detect and power inline devices
four-pair Four-pair PoE power
never Never apply inline power
police Police the power drawn on the port
port Configure Port Power Level
static High priority inline power interface
(config-if)#power efficient-ethernet ?
auto Enable automatic efficient ethernet on this interface
Also worth looking below information :
https://community.cisco.com/t5/networking-documents/error-message-ilpower-3-controller-port-err-controller-port/ta-p/3135761
BB
which PoE devices are connected to these ports ? Try a longer or higher category Ethernet cable, in combination with that command (Power inline port 2x-mode), and check if that makes a difference...
