Power Issues with 2960x
trilerian
I didn't really know where to put this.  I have 3 new 2960x's in a stack.  Switch 2 keeps losing power after a few hours.  Currently there is nothing but the flex cables and power cables plugged into the switches as I am going to replace our current stack with these.  Generally the switch loses power overnight and when I come in in the morning it is powered off, but still plugged in.  I can unplug it and wait for a bit, then plug it back in and it will power up.  If I don't wait, nothing will happen.  I have the switch separated right now on a different circuit to see if it will stayed powered on tonight.
I gave up and called Cisco TAC.  They are doing an RMA for hardware failure.
7 Replies 7
Leo Laohoo
Post the complete output to the command "remote command 2 sh log on up detail".
HINT: Put the output in a text file and attach it to your response or thread.
Here is the output of the cmd.
UPTIME SUMMARY INFORMATION
First customer power on : 01/05/2017 04:09:26
Total uptime : 0 years 0 weeks 6 days 4 hours 35 minutes
Total downtime : 1 years 46 weeks 5 days 12 hours 48 minutes
Number of resets : 70
Number of slot changes : 1
Current reset reason : 0x0
Current reset timestamp : 04/30/2017 15:33:39
Current slot : 2
Current uptime : 0 years 0 weeks 0 days 3 hours 0 minutes
Reset | |
Reason | Count |
No historical data to display
UPTIME CONTINUOUS INFORMATION
Time Stamp | Reset | Uptime
MM/DD/YYYY HH:MM:SS | Reason | years weeks days hours minutes
01/05/2017 04:09:26 0x0 0 0 0 0 0
01/05/2017 04:14:29 0x0 0 0 0 0 10
01/05/2017 04:56:47 0x0 0 0 0 0 30
01/05/2017 04:09:26 0x0 0 0 0 0 55
04/11/2017 21:12:48 0x0 0 0 0 0 0
04/11/2017 21:12:50 0x0 0 0 0 0 0
04/12/2017 06:18:53 0x0 0 0 0 0 0
04/11/2017 21:12:44 0x0 0 0 0 0 0
04/12/2017 06:18:54 0x0 0 0 0 0 0
04/11/2017 21:12:51 0x0 0 0 0 0 5
04/12/2017 06:19:03 0x0 0 0 0 0 0
04/12/2017 06:18:59 0x0 0 0 0 0 0
04/11/2017 21:08:38 0x0 0 0 0 0 0
04/11/2017 21:12:51 0x0 0 0 0 0 0
04/11/2017 21:12:55 0x0 0 0 0 0 0
04/12/2017 06:19:00 0x0 0 0 0 0 0
04/11/2017 21:12:52 0x0 0 0 0 0 0
01/05/2017 04:09:26 0x0 0 0 0 0 15
01/05/2017 04:09:26 0x0 0 0 0 0 10
01/14/2017 05:02:27 0x0 0 0 0 0 5
01/14/2017 16:23:10 0x9 0 0 0 11 0
01/14/2017 17:44:02 0x9 0 0 0 1 0
01/14/2017 22:53:05 0x0 0 0 0 4 0
01/14/2017 02:06:39 0x0 0 0 0 0 0
01/14/2017 19:58:07 0x0 0 0 0 17 0
01/14/2017 21:04:03 0x0 0 0 0 0 50
01/15/2017 18:37:17 0x0 0 0 0 20 0
01/17/2017 06:09:53 0x0 0 0 1 11 0
01/17/2017 20:45:18 0x0 0 0 0 14 0
01/21/2017 20:20:50 0x0 0 0 0 4 0
03/14/2017 10:37:57 0x0 0 0 0 2 0
03/14/2017 11:17:40 0x0 0 0 0 0 25
03/19/2017 11:16:31 0x0 0 0 0 7 0
03/22/2017 11:44:45 0x0 0 0 0 12 0
03/22/2017 16:19:19 0x0 0 0 0 4 0
04/29/2017 16:52:27 0x0 0 0 0 1 0
04/30/2017 11:32:36 0x0 0 0 0 7 0
04/30/2017 15:23:49 0x0 0 0 0 3 0
04/30/2017 15:33:39 0x0 0 0 0 0 0
Hmmmm ...
Can you post the complete output to the command "dir flash2:"?
Here it is thanks!
Directory of flash:/
2 -rwx 1096 May 1 2017 11:35:46 +00:00 vlan.dat
3 -rwx 2072 Apr 30 2017 15:40:51 +00:00 multiple-fs
4 -rwx 3853 Apr 30 2017 15:40:51 +00:00 private-config.text
5 -rwx 50163 Apr 29 2017 16:55:33 +00:00 config.text.backup
6 drwx 512 Jan 1 1970 00:02:42 +00:00 c2960x-universalk9-mz.152-4.E7
671 drwx 512 Dec 7 2016 22:12:31 +00:00 dc_profile_dir
673 -rwx 3853 Apr 29 2017 16:55:35 +00:00 private-config.text.backup
674 -rwx 50184 Apr 30 2017 15:40:50 +00:00 config.text
122185728 bytes total (91742720 bytes free)
Also, it went down again last night.  Was powered off this morning when I came in.  Unplugged for 5 minutes then plugged back in and it came back up.
does your model have an exchangeble power module?
while waiting for TAC to respond you could try swapping Power modules,
see if the problem moves to the other switch or remains in the same chassis.
Thanks for the reply, but TAC already sent out a new switch.  It was under hardware warranty.  It will be here today.
