power stack has unbalanced power supplies
hi,
I am receiving the following error on 3750 stack switches. have already verified the power status and found ok.
IOS used: Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
211540: Jun 10 10:45:17.935 UTC: %PLATFORM_STACKPOWER-4-UNBALANCED_PS: Switch 4's power stack has unbalanced power supplies
211541: Jun 10 10:46:18.045 UTC: %PLATFORM_STACKPOWER-4-UNBALANCED_PS: Switch 4's power stack has unbalanced power supplies
211542: Jun 10 10:47:18.148 UTC: %PLATFORM_STACKPOWER-4-UNBALANCED_PS: Switch 4's power stack has unbalanced power supplies
3750-switch#sh env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
TEMPERATURE is OK
Temperature Value: 28 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-1100WAC    LIT16391DUN  OK              Good     Good     1100/0
1B  C3KX-PWR-1100WAC    LIT160129MW  OK              Good     Good     1100/0
2A  C3KX-PWR-1100WAC    LIT16391DVJ  OK              Good     Good     1100/0
2B  C3KX-PWR-1100WAC    LIT16010268  OK              Good     Good     1100/0
3A  C3KX-PWR-1100WAC    LIT16391DT7  OK              Good     Good     1100/0
3B  C3KX-PWR-1100WAC    LIT160129LU  OK              Good     Good     1100/0
4A  C3KX-PWR-1100WAC    LIT16391DS1  OK              Good     Good     1100/0
4B  C3KX-PWR-1100WAC    LIT16010284  OK              Good     Good     1100/0
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
2   Not Present     <>
3   Not Present     <>
4   Not Present     <>
3750-switch#sh switch
Switch/Stack Mac Address : 4403.a7cf.e880
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 4403.a7cf.e880     15     1       Ready
2       Member 4403.a780.7d80     13     1       Ready
3       Member 4403.a7c8.9080     11     1       Ready
4       Member 4403.a748.8680     9      1       Ready
3750-switch#sh stack-power
Power stack name: Powerstack-2
    Stack mode: Power sharing
    Stack topology: Ring
    Switch 1:
        Power budget: 1663
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1: 4403.a780.7d80
        Neighbor on port 2: 4403.a748.8680
    Switch 2:
        Power budget: 1663
        Low port priority value: 20
        High port priority value: 11
        Switch priority value: 2
        Neighbor on port 1: 4403.a7c8.9080
        Neighbor on port 2: 4403.a7cf.e880
    Switch 3:
        Power budget: 1663
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Neighbor on port 1: 4403.a748.8680
        Neighbor on port 2: 4403.a780.7d80
    Switch 4:
        Power budget: 1663
        Low port priority value: 19
        High port priority value: 10
        Switch priority value: 1
        Neighbor on port 1: 4403.a7cf.e880
        Neighbor on port 2: 4403.a7c8.9080
3750-switch#
CCIE 37523
Have tried the below given fix given by cisco on bug toolkit but it didnt work so final solution to problem is "UPGRADE THE IOS"
3750(config)#stack-power switch ?
  <1-9>  Switch number
3750(config)#stack-power switch 1
3750(config-switch-stackpower)#?
  standalone      Configure switch to not participate in power stack
3750(config-switch-stackpower)#standalone
!!! wait for 20 sec
3750(config-switch-stackpower)#NO standalone
CCIE 37523
