07-02-2012 12:26 AM - edited 03-07-2019 07:33 AM
I need 3925 router and i want to install SM-ES3G-16-P etherswitch module with PoE into it. So my question is do I need PoE power supply or not? Will PoE ports on this module work with basic AC power supply?
07-02-2012 03:17 PM
Depends on your power supply. Have a look at table-3 in this link:
07-02-2012 08:00 PM
Thank you for your reply. I've read the document, but it is still not clear to me though.
Document says: "Power over Ethernet requires the PoE versions of the router power supplies". I have two PWR-3900-AC power supplies in the 3925 router (not PoE versions). So I will have no PoE on the etherswitch ports? (despite the fact that there is enough power on this two power supplies to set PoE up)
