primary and backup static routing
Giuliano Cocchi
i need to define primary and backup static routing on my L3 switch.
I cannot use dynamic routing, so i need info/docs about this kind of configuration.
Someone can help me?
Thank you.
mahmoodmkl
Level 7
Level 7
hi
u need to configure one static route with AD of 1 which is by default and other with higher AD
1.1.1.0 255.255.255.0 2.2.2.2
1.1.1.0 255.255.255.0 3.3.3.3 5
This does not work, because i have svi interfaces, and primary route go away from routing table only when svi interface goes down, and this does not happen in any case.
mahmoodmkl
Level 7
Level 7
in this case i just to use ip sla with tracking which will help
search for this feature on cisco u will find many examples
