Priority queue on ME3400
Iulian Vaideanu
Level 11
Level 11
I'm trying to deploy a simple traffic prioritization on a ME3400G-2CS running metroipaccessk9-mz.122-55.SE11 and I'm not sure whether I'm being successful or not.  Under interface Gi0/3 I have "service-policy output out-policy-dtv", where
class-map match-any out-class-dtv
 match cos  4
policy-map out-policy-dtv
 class out-class-dtv
    priority
"show platform qos debug interface queueing" says
GigabitEthernet0/3
Egress Priority Queue : enabled
Shaped queue weights (absolute) :  0 0 0 0
Shared queue weights  :  1 255 255 4
The port bandwidth limit : 100  (Operational Bandwidth:100.0)
The port is mapped to qset : 4
But a while after "clear counters", "show platform qos statistics interface gigabitEthernet 0/3" shows a lot of "cos: outgoing" packets for CoS 4, while "show policy-map interface gigabitEthernet 0/3" shows zero packets for "Class-map: out-class-dtv".  So, is that class-map matched against or not?
  cos: outgoing
  0 -  4 :      184026            0            0            0      1921699
  5 -  7 :           0            2            1
 GigabitEthernet0/3
  Service-policy output: out-policy-dtv
    Class-map: out-class-dtv (match-any)
      0 packets
      Match: cos  4
        Priority
      Output Queue:
        Max queue-limit default threshold: 160
        Tail Packets Drop: 0
    Class-map: class-default (match-any)
      4203766 packets
      Match: any
        Output Queue:
          Tail Packets Drop: 405
Hitesh Vinzoda
Level 10
Level 10
Hi dude,
Lets first check the dependencies, as per the config guide. Is your port a dot1q trunk?
Classification Based on Layer 2 CoS
You can use the match command to classify Layer 2 traffic based on the CoS value, which ranges from 0 to 7.
Note A match cos command is supported only on Layer 2 802.1Q trunk ports.
This example shows how to create a class map to match a CoS value of 5:
Switch(config)# class-map premium
Switch(config-cmap)# match cos 5
Switch(config-cmap)# exit
Yes, the port has
 port-type nni
 switchport trunk allowed vlan 110,111,994
 switchport mode trunk
I read this in the config guide: "An output policy map attached to an egress port can match only the packets that have already been matched by an input policy map attached to the ingress port for the packets."
So I created the maps below, which I applied (on input) on the interface the traffic of interest comes in.  Now I have matches of out-policy-dtv on Gi0/3, but I have no matches (not even for class-default) of in-policy-dtv on the other interface :)...
class-map match-any in-class-dtv
 match cos  4
policy-map in-policy-dtv
 class in-class-dtv
  set cos 4
