11-28-2014 03:57 PM - edited 03-07-2019 09:42 PM
Has anyone worked with private vlans on ESXi Vmware trunked to a Cisco 3750 switch also using private vlans?
ESXi-->Cisco 3750-->Firewall ->Internet
Is this supported ?
11-28-2014 04:07 PM
Hello
I can honestly say I have not - but I guess once in the switch the features are applicable
What is it you wish to know -I assume does it work?
res
Paul
11-29-2014 03:07 AM
Hi Paul,
I have private vlans configured on both but cannot ping default gateway which is firewall.
11-29-2014 07:11 AM
If you have multiple primary vlans configured, the connection to the firewall needs to be configured as trunk.
see config guide below:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/configuration/guide/scg3750/swpvlan.html#wp1047919
11-29-2014 08:54 AM
I have 2 x 3750 Switches in a stacked configuration (see diagram and config)
The uplink to Internet firewall is a active/backuplink using normal switch port.
The link to the LAN Firewall is the only one trunked.
Primary Secondary Type Ports
255 10 community Gi1/0/1, Gi1/0/18, Gi2/0/18
255 20 community Gi1/0/1, Gi1/0/19, Gi2/0/19
255 30 isolated Gi1/0/1
There is a proxy Server which is needed to get to internet this is connected to cisco switch port 1/0/5 which is also on Vlan 255 , does it need a private vlan ?
Cant ping default gateway 192.168.255.101
03-18-2015 08:31 AM
I know is stupid and late, but are your Firewall pingable?
I'm going through the same issue.
