Private VLANs simple config help
Andy White
Level 3
Level 3
Have you ever had an area of network that doesn't 'click' with you, well PVLANs just isnt with me.  It seems we have a site that is on one VLAN that has hosts that shouldn't be able to communicate with each other, but need to talk to an on-site server in the same VLAN and remote servers via the router, how can I do this?  I'm wondering if someone can help with the config and it may make sense on a LAN I understand.
Or can VACLs do this?
blau grana
Level 7
Level 7
Hello Andy,
This config should do it:
hostname switch1
vlan 100
private-vlan primary
private-vlan association 10
vlan 10
private-vlan isolated
int xyz
description to host
switchport private-vlan host
switchport mode private-vlan host-association 100 10
hostname switch2
vlan 100
vlan 10
int xyz
description to host
switchport private-vlan host-association 100 10
hostname switch-empty
vlan 100
vlan 10
int xyz
description to server
switchport mode private-vlan promiscuous
switchport mode private-vlan mapping 100 10
int xyz
description to router
Each switch has to be manually configured with vlans (VTP do not support private vlans) and mappings.
Trunks between switch must allow both vlans.
Check this for details:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/pvlans.html
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
So I am trying to understand this, you created a new VLAN (100) and put the router and server into it and associated VLAN 10 with 100 and isolated the host ports so they can't communicate with each other and set the server and router to promiscuous mode as they need to contact everything?
yes.
primary vlan 100 is associated with isolated vlan 10.
isolated vlan - hosts associated with this vlan can reach only primary vlan, not any other secondary vlan(isolated, community) also host associated with this vlan cannot communicate with each other, they can communicate only with primary vlan.
host vs promiscuous
host - switchport connected to regular host, port communicate only with promiscuous ports or ports on same community vlan, not with same ports in isolated vlan.
promiscuous - switchport connected to router (some gateway), this type of port can communicate with any ports associated with primary or secondary vlans.
Best Regards
