Cisco Router VPN client SPlit tunnel is not working
Lasandro Lopez
Hello there!
i've configured Cisco VPN CLient on a router 2821, and it is working fine.
I could access inside resourses normally>
the problem is that when i connect with VPN i lost connectivity to internet?
What is wrong with my configuration?
Below the running config of the router.
Regards!
CISCO2821#sh run
Building configuration...
Current configuration : 5834 bytes
version 12.4
hostname CISCO2821
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-20.T.bin
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
aaa new-model
aaa authentication login VPN-LOCAL-AUTHEN local
aaa authorization network VPN-LOCAL-AUTHOR local
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip domain name yourdomain.com
ip name-server 8.8.8.8
no ipv6 cef
voice-card 0
no dspfarm
username vpn privilege 0 secret 5 $1$tCf1$XAxQWtDRYdfy9g3JpVSvZ.
archive
log config
  hidekeys
crypto isakmp policy 44
encr aes
authentication pre-share
group 2
lifetime 44444
crypto isakmp client configuration group VPN
key VPNVPNVPN
pool VPN-POOL
acl VPN-ACL-SPLIT
max-users 5000
crypto isakmp profile VPN-ISAKMP-PROFILE
   match identity group VPN
   client authentication list VPN-LOCAL-AUTHEN
   isakmp authorization list VPN-LOCAL-AUTHOR
   client configuration address respond
   virtual-template 44
crypto ipsec transform-set VPN-SET esp-aes esp-sha-hmac
crypto ipsec profile VPN-PROFILE
set transform-set VPN-SET
set isakmp-profile VPN-ISAKMP-PROFILE
interface GigabitEthernet0/0
ip address 192.168.2.214 255.255.255.0
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1412
duplex auto
speed auto
interface GigabitEthernet0/1
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/0
no ip address
shutdown
duplex auto
speed auto
interface Virtual-Template44 type tunnel
ip unnumbered GigabitEthernet0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN-PROFILE
interface Dialer0
no ip address
ip mtu 1452
shutdown
ip local pool VPN-POOL 192.168.1.150 192.168.1.250
ip forward-protocol nd
ip http server
ip http port 8081
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list ACL-NAT interface GigabitEthernet0/0 overload
ip access-list standard ACL-TELNET
permit any
ip access-list extended ACL-NAT
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended ACL-VPN-SPLIT
permit ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
ip access-list extended VPN-ACL-SPLIT
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
access-class ACL-TELNET in
exec-timeout 30 0
privilege level 15
logging synchronous
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
privilege level 15
logging synchronous
line vty 16 988
exec-timeout 30 0
logging synchronous
scheduler allocate 20000 1000
end
CISCO2821#
Gregory Snipes
Level 4
Level 4
I believe you have made an error with your ACL name. the ACL applied is "VPN-ACL-SPLIT" which is a blank ACL. You should switch that to "ACL-VPN-SPLIT" which has the entry "permit ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255" in it.
blau grana
Level 7
Level 7
Hello Lasandro,
I had this problem a few months ago with similar sympthoms. I dont think you lost internet connectivity.
How did you test your connectivity? From which OS are you logging to VPN?
My problem was that after logging into VPN, my DNS server changed to default gateway of VPN connection. If do not allow internet connection for VPN users, your DNS request will be dropped/not resolved. Same as you a did not config DNS server in my isakmp client configuration.
I had this problem with Linux (Ubuntu 10.04) and also with MacOS. WinXP was working with no problem.
So what OS are you using, and can you post output of ipconfig / ifconfig and route print / route before and after logging to VPN?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Gregory Snipes
Level 4
Level 4
Thank you Gregory. Your answer is the right one.
I correct the labeled ACL and now it is working fine.
Regards!
