Privilege command help
jasonbailey80
Community Member
I have a question on the username and privilege levels
These are the commands
username jason level5 password Jas0n
enable secret ***
privilege mode all level5 show
Q1. Can we use different enable secret for differnet levels on the same router to give access to different users?
Q2. When I login to the router enable mode i use the username of Jason and my password, so will that automatically out me level5 mode?
Thx for the help
Jason
ahmednaas
Level 8
Level 8
Yes you can. For "enable secret level x somepass", you need to enter "enable x" and use the password associated with that level.
or you can use the "username jason level 5 password Jas0n" for intial login to the router. You can configure your lines (con, aux, vty, line ...) to require a login username/password. When you login with a privilige level > 1, you are immediately in enable mode where you can excute commands associated with your level plus all lower level commands.
bjw
Level 8
Level 8
Jason, In your example, your Jas0n password will log you right into enable mode. The Enable secret password would be like a back door for someone who logged in with less than enable-level privileges, to be able to get to enable mode with an extra login step.
Check out this doc and you should get it.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a00800ca7cd.html
