privilege level access on CATOS
josephp
Hello folks. I need a little help. I'm trying to set up different privilege level access on my switches. I found out that 1 switch is running CATOS I don't know the command or if it is even possible to set it up. Please help.
username admin privilege 0 password 0 test
privilege exec level 0 terminal lenght 0
privilege exec level 0 show interfaces
________________
JP
Lucien Avramov
Level 10
Level 10
This could be accomplished on IOS, but there is no equivalent way to do this on CATOS.
You can use Command Authorization, which is possible only with tacacs+. You can use the cisco ACS server for that.
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a0080094ea4.shtml#f
The Catalyst has non-privileged (equivalent to '1') & privileged (equivalent to '15').
