Problem change failover in FWSM SP: shutdown_pc_process:No response from module 9
sergio1983mx
Its Sergio Peralta
I had a problem with a FWSM of 6500 because the FWSM primary change to standby and after back to active
I have this show log of the 6500
008275: Jan 16 22:41:54.525: %SNMP-5-MODULETRAP: Module 9 [Down] Trap
Jan 16 22:41:54: SP: The PC in slot 9 is shutting down. Please wait ...
Jan 16 22:42:09: SP: shutdown_pc_process:No response from module 9
Jan 16 22:42:19.525: %C6KPWR-SP-4-DISABLED: power to module in slot 9 set off (Reset)
Jan 16 22:44:32.862: %DIAG-SP-6-RUN_MINIMUM: Module 9: Running Minimal Diagnostics...
008276: Jan 16 22:44:36.423: %SVCLC-5-FWVTPMODE: VTP mode is set to non-transparent
008277: Jan 16 22:44:36.427: %MLS_RATE-4-DISABLING: The global switching mode is now 'truncated'. Disabling the Layer2 Rate Limiters.
008278: Jan 16 22:44:36.507: %SNMP-5-MODULETRAP: Module 9 [Up] Trap
Jan 16 22:44:36.254: %DIAG-SP-6-DIAG_OK: Module 9: Passed Online Diagnostics
Jan 16 22:44:40.104: %OIR-SP-6-INSCARD: Card inserted in slot 9, interfaces are now online
Please helpe and i hope that u are ok
Actually FWSM
FWSM# sh failover
Failover On
Failover unit Primary
Failover LAN Interface: FAILOVER Vlan 247 (up)
Unit Poll frequency 1 seconds, holdtime 5 seconds
Interface Poll frequency 3 seconds
Interface Policy 50%
Monitored Interfaces 29 of 250 maximum
Config sync: active
Version: Ours 3.1(4), Mate 3.1(4)
Last Failover at: 11:14:39 GMT Jan 17 2011
        This host: Primary - Active
regards
mostafaammar
Hi Sergio,
I have the same problem , Did you find any solution for it ????
