VLAN Advice
ssbauer3275
Community Member
Before I implement the VLAN setup I have configured I want to make sure I did all of it correctly.
Router SG300 L3 Router 192.168.0.93
VLAN10 - Servers
VLAN20 - Building B FOH - 192.168.2.1
VLAN30 - Building B BOH - 192.168.3.1
VLAN40 - Building A - 192.168.4.1
Port 24 - 28 Set as Tagged VLAN 10,20,30,40
Port 24 Internet Traffic
Port 25 Switch 1 Building B
Port 26 Switch 2 Building B
Port 27 Switch 3 Building B
Port 28 Switch 4 Building A
On the Sonicwall I have a static route for the 192.168.2.0, 192.168.3.0 and 192.168.4.0 networks going back to the 192.168.0.93 Router
All the Switches on the uplink port are set to trunk with tagged VLAN 10, 20, 30 & 40 setup.
On each port for each switch I have the ports untagged to the VLAN the devices should be on.
I have setup a DHCP relay to the DHCP server and associated each interface 192.168.2.0, 192.168.3.0 and 192.168.4.0
Am I missing anything else?
Did I do this correctly?
Any advice or comments would be appreciated.
Then I don't see anything being missed..
Edison Ortiz
Do you have a default route on the SG300 pointing to the SonicWall?
Yes, the Sonicwall IP is 192.168.0.1 which I have set on the Router 192.168.0.93
Awesome, thanks for you help.
