problem in 3620
dhimancisco
Community Member
We are facing the problemwhen we are booting the 3620 router.continuosly it is booting itself and showing the error which is attached here..please suggest us what the problem is....
thanks in advance
Richard Burts
Dhiman
I am not clear about the specifics of this error but clearly this IOS image is not working for this device. Has this router been running and has just developed this problem? If so it might suggest a problem with flash memory. To solve it investigate the flash and fix any problem detected.
Or is this an image that has just been loaded into the router? If so that would suggest that the image is corrupted or is not valid for this device. To fix it get a different image and try to load it.
Of course if you have a maintenance contract on this router you can open a case with TAC and they will be able to tell you more details about what the problem is.
Rick
Rick
