Problem in interface
chpmotry
Level 3
Level 3
Hello everyone, good time.
I have a wireless link. At different times, the connection between the radio and the switch is constantly up and down, and the bandwidth fluctuates between 100 megabits and 1 gigabit.
I also tested the network cable on the switch. The network cable is OK in terms of the connection of the wires according to the standard. There are several possibilities here: either the network cable is faulty. Either the radio's ether port is faulty or the switch port is faulty. I moved the switch port, but the problem still exists.
Do you think there is a solution?
Leo Laohoo
conf t
interface Gi 3/0/48
 speed auto 100
end
See if that stabilizes the connection.  Keep this link under observation for, at a minimum, a week.
6 Replies 6
Mark Elsen
                - Check the logs on the switch to investigate further,
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I attached switch loggs on my post now
  - @chpmotry   Ok, can you also check  logs on the mikrotek station bridge ?
  M.
Unfortunately, I turned the radio off and on and its logs stored in RAM were erased. But I saw them before they were deleted. In a day, for about two to three hours, at intervals of a few minutes, its Ethernet link connected to the switch would go up and down regularly. And sometimes the bandwidth would drop from one gigabit to a hundred megabits.
 - @chpmotry  In my opinion the problem is related to the external infrastructure : bridge and access point , not the switch. Try to get logs from those anyway and or tweak network settings on the bridge , if possible,
 M.
Leo Laohoo
conf t
interface Gi 3/0/48
 speed auto 100
end
