Problem in Stacking
Dear all,
I got opportunities to implement stacking.Can you please tell in stacking how many switch are connected maximum and minimum?
how to configure stacking between 7 switches?
After configure stacking how to connect core switch?
Here we are using 3750 switch.kindly suggest how to configure.I am waiting for anyone response.
Thanks and Regards,
Mohamed Kabeer.S
kabeer!
First see exact model of 3750 and see its data sheet, by the way 3750 can be up to 9 switches can be stacked but this figure can be vary on different models.
for configuration see these links:
https://supportforums.cisco.com/discussion/11033156/how-stack-2-3750-switches
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#intro
http://www.brandontek.com/cisco/stacking-cisco-3750-switches/
kazim
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
How to configure stack of 7?
You wire the stack together using it's stack cables.  Then you configure stack,which will behave like a single switch but with banks of ports (from each stack member).
With 3750 stacks, its "easiest" if switches are similar, including series family, IOS version and IOS feature set.  (NB: if you have an 3750G-12S in your stack, you'll also want all stack members to use same SDM template.
How to connect to core switch?
I would suggest Etherchannel, using ports from different stack members.  Cisco suggests, for 3750 stacks, the active stack master not host an uplink port.
