Problem in STP?
Dear All,
In this connectivity,I configured,HSRP For, VLAN 23 & VLAN-24  in  Edge Router 7604 PE1,
1.If i am configuring like this, i will be  getting flopping in PE2.
2.Then i changed the  connectivity,
PE1--VLAN24---> DLinkswitch2
PE2--VLAN24---> Dlink Switch1
That time my both the routers CPU utilization will be very high(100%)
3.If i am removing the cable between D-Link,
That time i cant able to reach the Servers which is connected to Switch.
In this case, what i have to do?
Thanks in Advance
Tks&Rgds
Senthil
17 Replies 17
Hi Senthil,
Just a few things.
You may want to  add the following to your HSRP config to make it more deterministic -:
standby  1 timers 1 3
  standby 1 priority 110
It doesn't solve the STP issue,  but fixing inconsistancies helps.
I notice that you are running MST.
MST is backward compatible with CST and will create a CST instance if the dlinks
don't support MST.
If the dlinks are manageable I would check and see if they support MST.
I also notice that you have your two VLANs in the default MST instance 0.
When you create a VLAn this is the default MST instance that VLAns will get dumped into.
To solve your problem I would run the following commands on the PE's as it will resolve any spanning
tree loops with MST -:
PE1:
PE1(config)#spanning-tree mst 0 root primary
PE2(config)#spanning-tree mst 0 root secondary
This runs a macro that calculated what STP priority it needs to win the root bridge election.
The root secondary command will cause PE2 to calculate the bridge priority to become the secondary root bridge.
This should fix it in theory, but if there is no real MST running on the dlink, it wont.
Let me know how it goes.
Chris
Dear Chris,
As Per your suggestion, i have configured the Priority and Timers in both Edge routers..
For VLAN 23, PE1-Active, PE2-Standby
For VLAN 24, PE2-Active, PE1-Standby
After that,i cant able access the internal vlan which is configured in the D-Link.
(Actually i configured the three VLAN in D-Link Switch, But physically i connected with two vlans only..
PE1(4/32)-->D-Link1(VLAN23)
PE2(4/33)-->D-Link2(VLAN24)
PE1(4/32)-->D-Link2(VLAN23)
PE2(4/33)-->D-Link1(VLAN24),
Then i configured Dlink1(1/48)--Dlink2(1/48) port as a trunk and tagged all the VLAN.
When i am configuring mst primary in PE1, i am getting this errors..
Now what to do?
% Failed to make the bridge root for mst 0
% It may be possible to make the bridge root by setting the priority
% for some (or all) of these instances to zero.
Then i cant able to access VLAN 25 which is in both D-Link...This is the complete scenerio.
Now what i will do ?
Tks&Rgds
Senthil
Dear Senthil Rajendra,
There is some serious problem with your HSRP config, i think it should be like this ,
PE_1 ---int vlan 23
standby 1 ip 10.237.16.61
standby 1 preempt
standby 1 priority 150
int vlan 24
standby 2 ip 10.237.16.125
standby 2 preempt
standby 2 priority 140
PE_2--int vlan 24
standby 2 preempt
standby 2  priority 150
standby 1 preempt
standby 1  priority 140
make sure that u allow all vlans , make sure whether u have created port channel command like int port channel ,switchport enclapuslation etc
