PROBLEM IN SUBNETs CLASSFULL AND CLASSLESS!!!!!!!
Anand Solgama
Level 3
Level 3
SUBNET PROBLEM
In classfull we can use 10.0.0.0/8 as class A so we can start subnettting from /8/9...upto/32 so in short we have to start from /8 ..upto /8 all r NETWORK....
But in classless 10.0.0.0 we can use from /1 right or /25 or any mask
Questions::
1-why no need to start from /8 on class A
/16 on class B etc ...why ??
2-why we can use NETWORK bits upto /9 /10/15 etc ....????
3-how to know I have been ask on 10.0.0.0/8 from classA(classfull) or classless so how to calculate???
I have good picture example attached with this message...
In that I used 172.16.1.1/16 so in classfull 172.16.0.0/16 start host from /17 right??? so UPTO /16 ALL ARE NETWORK AFTER THAT SUBNET AND HOSTlike in my picture
but in classless picture calculator start from /20 as well and UPTO /20 ALL ARE NETWORK AND AFTER THAT HOST AND SUBNET??why???
Jon Marshall
Anand
1) because it is classless so 10.0.0.0/1 is a perfectly valid range ie. that address covers all the class A networks
2) don't understand the question - please clarify
3)  10.0.0.0/8 is the classful address ie. a class A network uses 255.0.0.0 as the network mask
the above doesn't make a lot of sense. if you have 172.16.0.0/16 the first host address is 172.16.0.1 and the last host address is 172.16.255.254.
I'm not sure what your document is meant to be showing as the second window is empty.
Perhaps you could try and be more precise in exactly what you want to know ?
Jon
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Perhaps you're a bit confused about classful vs. classless addressing.
For both, we need some method to distinguish between the network portion of the address and the host portion of the address.
With classless, whenever we "send" a network IP address, we included a network mask.  This allows the "recipient" to know what portion of the address is to be used for the network number and which portion contains a host number.  This also allows us to have no predefined network/host boundaries.  So we can have 10.0.0.1/24 or 196.168.1.1/8; pretty much anything we want except for the IP addresses set aside for multicast and experimental.
With classfull addresses (when both bandwidth and router memory were very expensive, i.e. we don't want to send or store the mask), we determine what the network and host portions of the IP address are by some rules.  If the first bit of the IP address is zero, it's a class A (/8).  If the first bit of the address is a one, but the second bit is a zero, it's a class B (/16).  If both the first bit and second bits are ones, it's a class C (/24).  (BTW, there are also performance advantages to looking at just the first or first two bits on very early computers.)
Classfull is a neat "trick", but having just 3 predefined network masks is often rather inconvenient.  So, often the "natural" class networks were subdivided (i.e. subnetted).  Doing so, though, comes with a bunch of dos and don'ts, because network masks are not provided with the IP address.
Guru Mysoruu
Level 4
Level 4
Hi Anand,
IPv4 Ip address is 32 bit Binary address and which contains four octets.
so each octet is represented by eight bits
8 bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit
1286432168421
Class A0-12701111111
Class B128-19110111111
Class C192-22411011111
In Classfull,Class A network i.e 8 bit value 128 will never become one.In any other bit it may be 0 or one.at most it can have a value of 127.thats how classfull network defined.
Class A Network 10.0.0.0 can be represented has
10= (128*0)+(64*0)+(32*0)+(16*0)+(8*1)+(4*0)+(2*1)+(1*0)
   =8+2=10
0=(128*0)+(64*0)+(32*0)+(16*0)+(8*0)+(4*0)+(2*0)+(1*0)
  =0
=0
  =0
For class A Subnet mask
255= (128*1)+(64*1)+(32*1)+(16*1)+(8*1)+(4*1)+(2*1)+(1*1)
   =128+64+32+16+8+4+2+1
   =255
  =0
=0
  =0
For class A-It will start from 0-126,subnet will be 255.0.0.0 i.e /8
For Class B it will start from 128-192,subnet will 255.255.0.0.i.e /16
For Class C,it will start from 192-224,subnet will be 255.255.255.0 i.e /24
These are classfull networks.
In Classless network,as per our requirement changes will be done to subnet mask
In your Classfulll screen diagram,you have assigined 20 bits for network and 12 bit for host and for 16 subnets.i.e /20 network
In your classless,you have assigned 24 bit for network and 8 bit for host i.e /24 network
Guru
