Problem ping inter vlan
JbOne
Frequent Visitor
Frequent Visitor
Hi !
I'm sorry, i'm french and i don't speak English very well. I'm going to try explicated my problem.
Currently, i create one project with the software Cisco Packet Tracer, the pattern below show you my network topology.
The switch 3560-24PS is layer 3, his configuration is the following one :
- Vlan 30 = 192.168.30.1 255.255.255.0
- Vlan 40 = 192.168.40.1 255.255.255.0
- Vlan 50 = 192.168.50.1 255.255.255.0
Ports FastEthernet AccessMode:
- 1 = Vlan 30
- 2 = Vlan 40
- 3 = Vlan 50
IP Route :
- 192.168.30.0 255.255.255.0 192.168.30.1
- 192.168.40.0 255.255.255.0 192.168.40.1
- 192.168.50.0 255.255.255.0 192.168.50.1
Ip Routing = Activate
The computers :
- 1 connected in port 1 with IP = 192.168.30.10 255.255.255.0
- 1 connected in port 2 with IP = 192.168.40.10 255.255.255.0
- 1 connected in port 3 with IP = 192.168.50.10 255.255.255.0
My problem is i can't ping the laptop PC-Indus with PC-Bur and i don't understand.
Can you help me please ?
Best regards.
Johann
3 Accepted Solutions
Hi Johann,
Please share the output of "sh run" from your switch.
HTH,
Meheretab
Georg Pauwen
Hello, bonjour,
post the Packet Tracer file, we can then have a look at your project ourselves in Packet Tracer...
publiez le fichier Packet Tracer, nous pouvons ensuite jeter un oeil à votre projet nous-mêmes dans Packet Tracer ...
Non, mais je parle un petit peu de français. Et je sais comment utiliser Google traduction...:)
La configuration ci-dessous du routeur Router_MTR devrait être suffisante; il y avait un problème avec le routage statique. J'ai marqué les changements (en gras😞
Current configuration : 846 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router_MTR
ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 10.100.59.10 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
ip address 10.150.80.10 255.255.255.0
interface Serial3/0
no ip address
clock rate 2000000
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
ip classless
ip route 10.150.88.0 255.255.255.0 10.150.80.20
ip route 192.9.210.0 255.255.255.0 10.100.59.7
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
16 Replies 16
Hi Johann,
HTH,
Meheretab
Georg Pauwen
Hello, bonjour,
Thank you for your answers !
I can't upload my project, he don't accept the extension pkt.
Can you tell me how to do ?
Thank you.
Best regards.
Johann
rename the .pkt file to a .jpg file. They recently changed the forum so you cannot directly upload .pkt files anymore...
Ok ! I come rename the extension file pkt as jpg.
Thank you very much.
The problem is simply that the defaut gateway on PC-Bur needs to be 10.100.59.7, while you have set it to 10.100.59.10. Change it to 10.100.59.7.
Thanks Georg Pauwen !
I just try and it works but i have a other problem, if i want pinger Laptop-PT API from Laptop-PC-PHIL it dosn't work.
Best regards.
Johann
Check the link between Router_MTR (interface FastEthernet0/0) and Switch_MTR (interface FastEthernet0/3). Both are layer 3 devices, so you will need a common subnet shared between those two interfaces.
Thanks for your answer,
I don't understand very well your sentence "Both are layer 3 devices, so you will need a common subnet shared between those two interfaces."
The switch and the router have the same subnet, i don't unterstand ...
Best regards
Change your Router_MTR configuration as below:
no ip address
duplex auto
speed auto
interface FastEthernet0/0.59
encapsulation dot1Q 59
Good morning Georg Pauwen,
I try and you'll be the first to know, sorry for tomorrow tonight, it was late and I preferred to sleep.
Thanks.
Johann
JbOne
Frequent Visitor
Frequent Visitor
Here is my information feedback,
I put one capture below with 2 area (Lan 1 and 2), in Lan 2, PC-Bur, API, PC-Indus and Switch-MTR can comunicate via a different subnetwork but they can't comunicate to Router-MTR.
In Lan 1, PC-PHIL can't communicate to Switch-MTR but work with Router-MTR.
The configuration that you give seems correct, i have good understand the encapsulation but i don't understand why i does not work ?
The network is not easy.
Thank you for you help.
Bonjour,
Essayez-vous simplement d'avoir une communication complète entre tous les appareils, ou existe-t-il des exigences particulières pour votre réseau? Il existe de nombreuses façons d'obtenir une connectivité complète ...
Bonjour,
Vous êtes français ?
@Georg Pauwen wrote:
Bonjour,
Oui effectivement je dois avoir une communication complète entre tous les appareils (distant et dans le même lan).
Il y a donc plusieurs sous-réseau qui sont gérés par un seul et même switch qui fait la passerelle vers le routeur.
Une machine A dont son IP est 10.100.59.87 pourra communiquer vers une machine dont l'IP est 192.9.210.34 dans le même LAN. Une personne dont l'IP est 10.150.88.97 dans un LAN différent pourra aussi communiquer vers les machines mentionnées précédemment. C'est pour cela qu'il y a 2 routeurs mais ça je pense que vous l'avez compris ?
Je sais pas si j'ai été assez précis dans mes réponses, pour être honnête, je suis purement auto-didacte, je débute donc mille excuses si je n'emplois pas les bons termes ou autres.
En tout cas, c'est très gentil de votre part de m'aider.
Cordialement.
Johann
