Problem ping inter vlan
JbOne
Frequent Visitor
Frequent Visitor
Hi !
I'm sorry, i'm french and i don't speak English very well. I'm going to try explicated my problem.
Currently, i create one project with the software Cisco Packet Tracer, the pattern below show you my network topology.
The switch 3560-24PS is layer 3, his configuration is the following one :
- Vlan 30 = 192.168.30.1 255.255.255.0
- Vlan 40 = 192.168.40.1 255.255.255.0
- Vlan 50 = 192.168.50.1 255.255.255.0
Ports FastEthernet AccessMode:
- 1 = Vlan 30
- 2 = Vlan 40
- 3 = Vlan 50
IP Route :
- 192.168.30.0 255.255.255.0 192.168.30.1
- 192.168.40.0 255.255.255.0 192.168.40.1
- 192.168.50.0 255.255.255.0 192.168.50.1
Ip Routing = Activate
The computers :
- 1 connected in port 1 with IP = 192.168.30.10 255.255.255.0
- 1 connected in port 2 with IP = 192.168.40.10 255.255.255.0
- 1 connected in port 3 with IP = 192.168.50.10 255.255.255.0
My problem is i can't ping the laptop PC-Indus with PC-Bur and i don't understand.
Can you help me please ?
Best regards.
Johann
16 Replies 16
Non, mais je parle un petit peu de français. Et je sais comment utiliser Google traduction...:)
La configuration ci-dessous du routeur Router_MTR devrait être suffisante; il y avait un problème avec le routage statique. J'ai marqué les changements (en gras😞
Current configuration : 846 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router_MTR
ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 10.100.59.10 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
ip address 10.150.80.10 255.255.255.0
interface Serial3/0
no ip address
clock rate 2000000
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
ip classless
ip route 10.150.88.0 255.255.255.0 10.150.80.20
ip route 192.9.210.0 255.255.255.0 10.100.59.7
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
Thanks Georg Pauwen,
I continu of speak english even if I am bad 😉
I did what you tall me but no it work, watching the running config, i have looked at your configuration and i noticed there was an error in my config.
Before :
interface FastEthernet0/0.59
encapsulation dot1Q 59
After :
no ip address
interface FastEthernet 0/0
Ip Address 10.100.59.10 255 255.255.0
Now it works correctly.
Thanks very much for your help, it is really nice from you.
Best regards.
Johann
