problem qos on c3750x Stack
lbellicaud
Level 2
Level 2
Hi All,
I want classify and marking traffic on access port with C3750x Ios:12.2(58)SE2 Lanbase but i don't have any packet.
With the same configuration on C6500 it's ok.
Here my configuration on Switch:
interface GigabitEthernet1/0/1
switchport access vlan 25
switchport mode access
service-policy input policy-port-PM
mls qos
mls qos map cos-dscp 0 8 16 26 32 46 48 56
class-map match-all gold-CM
description Classification des flux Gold
match access-group name multicast-gold-ACL
class-map match-all bronze-CM
description Classification des flux Bronze
match access-group name bronze-ACL
class-map match-all silver-CM
description Classification des flux Silver
match access-group name silver-ACL
class-map match-all priority-queue-CM
description Classification des flux voix
match access-group name priority-ACL
policy-map policy-port-PM
class priority-queue-CM
   set dscp ef
class gold-CM
   set dscp af41
class silver-CM
   set dscp af31
class bronze-CM
   set dscp af21
class class-default
   set dscp default
ip access-list extended bronze-ACL
permit ip any 192.168.23.0 0.0.0.255
ip access-list extended multicast-gold-ACL
permit ip any 239.0.0.0 0.255.255.255
ip access-list extended priority-ACL
permit ip any 10.239.25.0 0.0.0.255
permit ip any 192.168.24.0 0.0.0.255
ip access-list extended silver-ACL
permit ip any 192.168.21.0 0.0.0.255
Here result:
sh policy-map int gi1/0/1
Service-policy input: policy-port-PM
   Class-map: priority-queue-CM (match-all)
     0 packets, 0 bytes
     5 minute offered rate 0 bps, drop rate 0 bps
     Match: access-group name priority-ACL
   Class-map: gold-CM (match-all)
     0 packets, 0 bytes
     Match: access-group name multicast-gold-ACL
   Class-map: silver-CM (match-all)
     0 packets, 0 bytes
     Match: access-group name silver-ACL
   Class-map: bronze-CM (match-all)
     0 packets, 0 bytes
     Match: access-group name bronze-ACL
   Class-map: class-default (match-any)
     0 packets, 0 bytes
     Match: any
Thanks for your help
acampbell
Please look at the link to the config guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_58_se/configuration/guide/swqos.html
Table 37-15 Commands for Displaying Standard QoS Information
show policy-map [policy-map-name [class class-map-name]]
Display QoS policy maps, which define classification criteria for incoming traffic.
Note Do not use the show policy-map interface privileged EXEC command to display classification information for incoming traffic. The control-plane and interface keywords are not supported, and the statistics shown in the display should be ignored.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Alex.
