Problem resolution DNS behind ASA5505
essaki_ihssan
Hi all;
I have two server behind a ASA5505, the first one 192.168.1.4 for resolution of DNS domain name (expl: cisco.com) under Windows 2003 and the second one 192.168.1.5 Exchange 2003 for mailing, I forwarde the ports 53 to 192.168.1.4 for DNS server, and the ports 25 and 110 to 192.168.1.5 for the mail server.
But it does not work, I have an error message when I send a message  (copy below) to a mailbox expl "user" of the domain expl "test.com".
Objet : Delayed Mail (still Being retried)
# THIS IS A WARNING ONLY. YOU DO NOT NEED TO RESEND YOUR MESSAGE. # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # #
Your message Could not be Delivered for 0 days, 1 hours, 0 minutes.
It will be retried Until it is 0 days, 3 hours, 0 minutes old.
For further Top assistance, please send mail to <postmaster>
If you do so, please include this problem report. You can delete your own text from the attached returned message.
<user@test.com>: 421 4.4.0 [internal] no MXs for this domain Could be Reached at this time
i think it's resolution domain name problem.
Please help, What should I do.
essaki_ihssan
there is no answer????
or it is no clear??
Can you post the policy map from the ASA?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Bjorntimmer
I don't think this is a problem in your asa. Their could be multiple problems. When I see this error message you got a problem with dns.
When you do a nslookup on the exchange server for the domain Cisco.com, do you get an result?
Hi Bjorn Timmer;
thanks for your answer but i have the first configuration installed with Cisco routeur 857 + Sever WIndows 2003 AD domain + Trendmicro SMTP Gateway and it work fine and the mail serveur work fine.
when i change the routeur and i add the ASA5505 i have this probleme so i think the probleme is the ASA.
in the router i forward all port to the interface outside of ASA.
Hi John Blakley,
Thanks; below the configuration.
Firewall# sh run
: Saved
ASA Version 8.4(4)
hostname Firewall
enable password jDUXMyqeIzxQIVgK encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 10.10.10.2 255.255.255.0
boot system disk0:/asa844-k8.bin
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network remote
host 192.168.1.4
object network domain
host 192.168.1.4
object network Poste_01
host 192.168.1.16
description Poste Hanane
object network poste_02
host 192.168.1.4
description nom
object network inside-net
subnet 192.168.1.0 255.255.255.0
object network uc500
host 192.168.1.190
object network GatewaySMTP
host 192.168.1.5
object network GatewayIMAP
host 192.168.1.5
object network GatewayPOP
host 192.168.1.5
object network dns
host 192.168.1.4
object network domainUDP
host 192.168.1.4
object network 60993TCP
host 192.168.1.4
object network 60993UDP
host 192.168.1.4
object-group service post-remote tcp
description 60993
port-object eq 3389
port-object eq 60993
object-group service post-domain tcp
port-object eq domain
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group icmp-type Ping
description ping commande
icmp-object 7
object-group service 60993 udp
access-list 101 extended deny icmp object Poste_01 any
access-list 101 extended permit tcp any object GatewayIMAP eq imap4
access-list 101 extended permit tcp any object GatewayPOP eq pop3
access-list 101 extended permit tcp any object GatewaySMTP eq smtp
access-list 101 extended permit tcp any object remote object-group post-remote
access-list 101 extended permit tcp any object domain eq 60993
access-list 101 extended permit udp any eq domain object domain eq domain
access-list 101 extended permit tcp any eq domain object domain eq domain
access-list 101 extended permit icmp any any
access-list 101 extended permit tcp any object uc500 eq telnet
access-list inside_access_in extended permit ip any any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) static interface service tcp 3389 3389
nat (inside,outside) static interface service tcp domain domain
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp telnet telnet
nat (inside,outside) static interface service tcp smtp smtp
nat (inside,outside) static interface service tcp imap4 imap4
nat (inside,outside) static interface service tcp pop3 pop3
nat (inside,outside) static interface service udp domain domain
nat (inside,outside) static interface service tcp 60993 60993
nat (inside,outside) static interface service udp 60993 60993
access-group inside_access_in in interface inside
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 10.10.10.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
http server enable
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
dhcpd address 192.168.1.20-192.168.1.50 inside
dhcpd dns 192.168.1.4 212.217.0.1 interface inside
dhcpd domain sotravo.com interface inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class class-default
  user-statistics accounting
service-policy global_policy global
prompt hostname context
: end
Bets regards.
