sever CPU Utilization
sherif safwat
Community Member
Dears,
     we have 2811 router with multiple servers connected to it's lan from which there are monitoring servers in between , the router suffers always from high cpu utilization
configuration has alot of ACLs & NAT & IPSEC Tunnel with wan bandwidth 20 M
Is there any method to reduce the high cpu utilization shown below !!
CPU utilization for five seconds: 90%/80%; one minute: 93%; five minutes: 90%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
104   737029848   427864243       1722  5.45%  5.65%  5.65%   0 IP Input
253    63392216    11081854       5720  1.04%  1.15%  1.12%   0 IP NAT Ager
260    82602372   137425723        601  0.64%  0.64%  0.66%   0 PDU DISPATCHER
   2     2475488     1070922       2311  0.48%  0.41%  0.35%   0 Load Meter
270        3696         267      13842  0.48%  0.49%  0.18% 514 Virtual Exec
164    39209976  1101640874         35  0.40%  0.29%  0.36%   0 HQF Shaper Backg
259    53255128   146875160        362  0.24%  0.31%  0.34%   0 IP SNMP
256    17800088   155666048        114  0.24%  0.16%  0.17%   0 PPP manager
  18   149527460    33336738       4485  0.24%  0.16%  0.16%   0 ARP Input
148      212776     5308439         40  0.08%  0.00%  0.00%   0 bsm_xmt_proc
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
The 2811 is a little small for 20 Mbps.  Your 5 second rate shows most of the CPU being consumed by "interrupt", which normally reflects overall traffic loading.
However, ideally "interrupt" CPU should be almost all your CPU, and with tunnels, if you're fragmenting, you're CPU usage will be higher than necessary.  In other words, you might be able to improve CPU utilization if you optimize your configuration, assuming it's not optimal.
Have u enable any type of logging for ACLs
Jawad
No , Logging is not enabled for ACL , also minimized ACL as much as possible
regarding tunnel , how to check fragments through tunnels and how to adjust them !
Disclaimer
Posting
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_white_paper09186a00800d6979.shtml
