Problem summarization networking protocol EGRP Switch 6880
The problem that arises is that summarizes the network I portocolo EGRP, are implementing EIGRP dynamic routing on a switch 6880, when validated in neighboring router networks are with mask / 24 and no / 21
Someone happened this
13 Replies 13
Jon Marshall
Can you post the EIGRP configuration from your switch ?
Jon
Hi Jon,
Te annex the configuration
router eigrp 200
 network 10.116.136.0 0.0.7.255
 network 10.124.136.0 0.0.7.255
 network 10.124.136.128 0.0.0.31
 redistribute connected
 passive-interface default
 no passive-interface Vlan999
 no passive-interface Vlan30
interface Vlan999
 description XXXXX
 ip address 10.124.136.133 255.255.255.224
interface TenGigabitEthernet5/13
 description Router WAN
 switchport
 switchport access vlan 999
 switchport mode access
the connection is established between the switch 6880 and router 3945
It's not clear which routes are showing as /24s on the router ?
Can you pick one of the routes and -
1) can you post the interface configuration from the switch for that IP subnet
and
2) the route as it appears on the router
note that it is the actual mask used on the interface IP subnet that is important, not what you put under the EIGRP configuration.
Jon
Annex the info to switch
VLAN
interface Vlan220
description VOZ_XXXXX
ip address 10.116.140.11 255.255.255.0
glbp 220 ip 10.116.140.10
glbp 220 timers 1 3
glbp 220 preempt delay minimum 3
glbp 220 load-balancing host-dependent
glbp 220 authentication text Pr0yadmon
glbp 220 forwarder preempt delay minimum 3
VLAN adyacencia EIGRP
interface Vlan999
description VPNACOL1
delay 1000
Interface EIGRP
switchport
Annex the info to Router  ************************************
Interface EIGRP
interface GigabitEthernet0/0
 description Lan_
 ip address 10.124.136.131 255.255.255.224
 duplex auto
 speed auto
 router eigrp 200
 network 10.96.6.96 0.0.0.3
 network 10.124.144.0 0.0.7.255
 redistribute ospf 16205 metric 100000 100 255 1 1500
the router learns networks  /24 and not  /21
Do you mean the router has a route for -
10.116.140.0 255.255.255.0
instead of -
10.116.136.0 255.255.248.0
if so that is what you would expect.
On your switch under the EIGRP configuration the "network 10.116.136 0.0.7.255" statement only tells the switch which interfaces to run EIGRP on.
So EIGRP is run on vlan 220 because the IP subnet is in the above range.
But the actual subnet mask advertised to the router is the one on the interface of vlan 220.
That is the way IGPs work unlike BGP where the "network ..." statement is the actual network advertised.
If you want to summarise to the router then under the interface on the switch that connects to the router you can use a summary address eg. -
int vlan 999
ip summary-address eigrp 200 <summary address> <mask>
Jon
Hi Jon,
Since the ip summary-address on the vlan interface was applied and did not work,
Armando
On the switch can you do "sh ip eigrp neighbors"  and post output.
What command did you use under the interface ?
What exactly didn't work ie. an example.
Jon
Hi Jon,
I was set up on the vlan interface and does not work
int vlan 99
ip summary-address eigrp 200 10.116.136.0 255.255.248.0
So even after adding that command are you still seeing /24s in the IP routing table on the router that are within that IP subnet range ?
Jon
Yes,   continues to be the network / 24s.
Armando
It's hard for me to help because I can't see the routing tables and you are giving minimal information in your answers.
Do you see the summarised route in the router's routing table ?
Does the switch peer with any other device using EIGRP ?
Jon
No, in the router`s table i dont see the summarised routes.
Yes, the diagram is:
Router ==> Swtich 6880 =(portchannnel) Switch 6880
The switches are the core, and both use EIGRP,
This is the configuration of Router:
description Lan
duplex auto
speed auto
This is the configuration of router
router eigrp 200
offset-list 99 out 500 GigabitEthernet0/0
router ospf 16205
redistribute eigrp 200 subnets
network 10.96.6.96 0.0.0.3 area 0
network 10.162.127.48 0.0.0.7 area 0
This is the configuration of Core 1:
                interface Port-channel10
switchport
switchport trunk allowed vlan 10,20,30,31,103,109-115,120,203,209-215,220,999
switchport mode trunk
switchport
interface Vlan999
delay 1000
router eigrp 200
network 10.120.66.160 0.0.0.15
offset-list 99 out 500 Vlan999
This is the configuration of Core 2:
description Trunk SW 1
switchport
interface Vlan999
description RTRVOZAVCOL
ip address 10.124.136.132 255.255.255.224
router eigrp 200
no passive-interface Vlan31
Can you add the 10.116.136.0 255.255.248.0 summary address to both vlan 999 interfaces ie. on both switches.
Jon
