Problem to Access to web Access on 3750G
Translator
Community Manager
Community Manager
Hello
When I want to access the web interface, I get the following page, I don't understand I have the html directory.
Thanks in advance
10 Replies 10
balaji.bandi
for now we are not sure what is the issue ?
can you login from console post
show run
show version
dir
BB
Hello
here are the screenshots
still we are not sure what is the issue, we are not able to view show run full config.
try different browser https://switchip ?
BB
I tried the http and https protocols on firefox, edge and chrome without result. i then checked the html directory and then posted the question.
Is this the text below that you want?
Building configuration...
Current configuration: 3557 bytes
version 12.2
no pad service
timestamps debug datetime msec
timestamps log datetime msec service
no service password encryption
hostname iSwitch
boot-start marker
boot-end marker
enable secret 5 ************************************************
enable password ******************************************************************************
no aaa new model
switch 1 provision ws-c3750g-24ps
system mtu routing 1500
authentication mac-move permit
iSwitch#show run
version 12.2
no pad service
hostname iSwitch
boot-start marker
boot-end marker
no aaa new model
enable myCluster 0 cluster
crypto pki trustpoint TP-self-signed-2796259840
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2796259840
revocation check none
rsakeypair TP-self-signed-2796259840
crypto pki certificate chain TP-self-signed-2796259840
self-signed certificate 01
30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43 657274
69666963 6174652D 32373936 32353938 3430301E 170D3933 303303 1,3030,3031
33365A17 0D323030 31303130 30303030 305A3031 312F302D 0603504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 6696361 74652D323 7393632
35393834 3030819F 300D0609 2A864886 F70D0101 01050003 818D030 81890281
8100C21E D67D02DF 4B914BBE FF52858E 1602EB25 B387E499 56F95CDF F4B37D00
948D5848 491D7D73 3AFA64C7 3BA3BB68 8E0BDC07 4D0B799C BD9B6924 997FD4E5
737FF226 762CE122 FBB526D7 5002CA25 4AECCAEE 893BB930 55060BD4 3599B9BB
9FD543CF FD362169 7ECB4E03 9AFBED0E D41E7284 771EBDF4 8CBFBA61 AB45597E
59D30203 010001A3 68306630 0F060355 1D130101 FF040530 030101FF 31 30603
551D1104 0C300A82 08695377 69746368 2E301F06 03551D23 04183018 014D0CA
9D6FFC55 466BCB63 D23F224 9F947DEE 451C301D 0603551D 0E041604 14D0CA9D
6FFC5546 6BCB63D2 3F2249F 947DEE45 1C300D06 092A8648 86F70D01 01040500
03818100 534634A2 CABCDB69 5929595E 260E7B07 BD970588 D7C55941 BAE61B19
373BA3E0 5D75286C EE93E4A0 8F1BA63D E6318EF8 3BC033E6 BEDD3B37 E528AE0E
B42F8B11 BCC0373E 7810E13E 89E960BE A98C1575 CEFC292D A9D64DCA 774A839D
40C13F1C AC37A04A FEEC2748 4508D1B5 68FC1745 97EFA511 DD4AADAD EEB00849 7BB5DB5D
quit
pvst mode spanning tree
spanning tree extend system-id
vlan internal allocation policy ascending
Gigabit Ethernet1/0/1 interface
Gigabit Ethernet1/0/2 interface
Gigabit Ethernet1/0/3 interface
Gigabit Ethernet1/0/4 interface
Gigabit Ethernet1/0/5 interface
Gigabit Ethernet1/0/6 interface
Gigabit Ethernet1/0/7 interface
Gigabit Ethernet1/0/8 interface
Gigabit Ethernet1/0/9 interface
GigabitEthernet1/0/10 interface
GigabitEthernet1/0/11 interface
GigabitEthernet1/0/12 interface
GigabitEthernet1/0/13 interface
switchport port-security mac-address 1cca.e379.0d4f
portfast spanning tree
GigabitEthernet1/0/14 interface
GigabitEthernet1/0/15 interface
GigabitEthernet1/0/16 interface
GigabitEthernet1/0/17 interface
GigabitEthernet1/0/18 interface
GigabitEthernet1/0/19 interface
GigabitEthernet1/0/20 interface
GigabitEthernet1/0/21 interface
GigabitEthernet1/0/22 interface
GigabitEthernet1/0/23 interface
GigabitEthernet1/0/24 interface
GigabitEthernet1/0/25 interface
GigabitEthernet1/0/26 interface
GigabitEthernet1/0/27 interface
GigabitEthernet1/0/28 interface
Vlan1 interface
ip address 192.168.1.6 255.255.255.0
ip default-gateway 192.168.1.254
ip classless
http server ip
http ip secure-server
ip sla enable reaction-alerts
snmp-server community RO
snmp-server community public@es0 RO
vstack
line con 0
exec-timeout 0 0
line vty 0 4
login
line vty 5 15
login
end
Can you post inside the content of IOS Folder example :
dir flash:/C3750XXXXXXXXXXXXXXXXXXXXXXX
also HTTP GUI config as below @
Using the GUI , you have must have permission of privilege level 15 access try below option :
create a user
Step 1
username admintemp privilege 15 privilege 15 secret admintemp
then runn the http services
Step 2
ip http server
ip http secure-server
ip http authentication login local
Step 3
management ip
http://X.X.XX
it will ask you username and pass
make sure you have right java version.
BB
iSwitch#dir flash:/c3750-ipbasek9-mz.122-55.SE12
Directory of flash:/c3750-ipbasek9-mz.122-55.SE12/
4 -rwx 684 Mar 1 1993 01:00:47 +00:00 info
10 drwx 4800 Mar 1 1993 01:02:00 +00:00 html
514 -rwx 12111413 Mar 1 1993 01:07:12 +00:00 c3750-ipbasek9-mz.122-55.SE12.bin
32514048 bytes total (16806400 bytes free)
iSwitch#dir flash:/c3750-ipbasek9-mz.122-55.SE12/h
iSwitch#dir flash:/c3750-ipbasek9-mz.122-55.SE12/html
Directory of flash:/c3750-ipbasek9-mz.122-55.SE12/html/
11 -rwx 3500 Mar 1 1993 01:00:47 +00:00 ip.js
12 -rwx 39650 Mar 1 1993 01:00:48 +00:00 graph.js
13 -rwx 104256 Mar 1 1993 01:00:50 +00:00 smartports.js
14 -rwx 128746 Mar 1 1993 01:00:52 +00:00 dashboard.shtml
15 -rwx 577 Mar 1 1993 01:00:52 +00:00 title.js
16 drwx 1088 Mar 1 1993 01:00:58 +00:00 ja
51 -rwx 19448 Mar 1 1993 01:00:58 +00:00 graph_dash.js
52 -rwx 75667 Mar 1 1993 01:00:59 +00:00 portset.shtml
53 -rwx 2228 Mar 1 1993 01:00:59 +00:00 gaaggrement.html
54 -rwx 11219 Mar 1 1993 01:00:59 +00:00 xhome.htm
55 -rwx 12467 Mar 1 1993 01:01:00 +00:00 sitewide.js
56 -rwx 7174 Mar 1 1993 01:01:00 +00:00 sslhome.shtml
57 -rwx 5641 Mar 1 1993 01:01:00 +00:00 cna_upgrade.htm
58 drwx 1408 Mar 1 1993 01:01:03 +00:00 help2
81 -rwx 12811 Mar 1 1993 01:01:04 +00:00 setup_report.htm
82 -rwx 6642 Mar 1 1993 01:01:04 +00:00 telnet.shtml
83 -rwx 21032 Mar 1 1993 01:01:04 +00:00 toolbar.shtml
84 -rwx 4366 Mar 1 1993 01:01:04 +00:00 resettimer.htm
85 -rwx 62 Mar 1 1993 01:01:04 +00:00 more.txt
86 -rwx 519 Mar 1 1993 01:01:05 +00:00 nsback.htm
87 -rwx 6645 Mar 1 1993 01:01:05 +00:00 legend.htm
88 -rwx 51415 Mar 1 1993 01:01:05 +00:00 monitors ordata.shtml
89 -rwx 81609 Mar 1 1993 01:01:07 +00:00 smartports.shtml
90 -rwx 1018 Mar 1 1993 01:01:07 +00:00 redirect.htm
91 -rwx 6937 Mar 1 1993 01:01:07 +00:00 resettimer.shtml
92 drwx 1536 Mar 1 1993 01:01:11 +00:00 help
117 -rwx 8107 Mar 1 1993 01:01:11 +00:00 status.htm
118 -rwx 251 Mar 1 1993 01:01:11 +00:00 border.htm
119 -rwx 6825 Mar 1 1993 01:01:12 +00:00 express-setup.htm
120 -rwx 6383 Mar 1 1993 01:01:12 +00:00 toolbar.js
121 -rwx 950 Mar 1 1993 01:01:12 +00:00 frmwrkResource.htm
122 -rwx 4108 Mar 1 1993 01:01:12 +00:00 bottomanner.htm
123 -rwx 556 Mar 1 1993 01:01:12 +00:00 const.htm
124 -rwx 2858 Mar 1 1993 01:01:12 +00:00 googleanalytics.js
125 -rwx 8254 Mar 1 1993 01:01:12 +00:00 menu.shtml
126 -rwx 1654 Mar 1 1993 01:01:12 +00:00 menu.css
127 -rwx 846 Mar 1 1993 01:01:12 +00:00 reloadstatus.shtml
128 -rwx 369 Mar 1 1993 01:01:12 +00:00 printframe.htm
129 -rwx 1749 Mar 1 1993 01:01:12 +00:00 appsui.js
130 -rwx 39013 Mar 1 1993 01:01:13 +00:00 softwareupgrade-top.shtml
131 -rwx 40850 Mar 1 1993 01:01:14 +00:00 topbanner.htm
132 -rwx 48234 Mar 1 1993 01:01:15 +00:00 sorttable.js
133 -rwx 9818 Mar 1 1993 01:01:15 +00:00 menu.js
134 -rwx 33654 Mar 1 1993 01:01:15 +00:00 health.htm
135 -rwx 9847 Mar 1 1993 01:01:16 +00:00 portstats.js
136 -rwx 1804 Mar 1 1993 01:01:16 +00:00 softwareupgrade.htm
137 -rwx 865 Mar 1 1993 01:01:16 +00:00 helpframework.js
138 -rwx 50004 Mar 1 1993 01:01:16 +00:00 discover.shtml
139 -rwx 9353 Mar 1 1993 01:01:17 +00:00 combo.js
140 -rwx 2379 Mar 1 1993 01:01:17 +00:00 archestatus.shtml
141 -rwx 4829 Mar 1 1993 01:01:17 +00:00 convert.js
142 -rwx 108511 Mar 1 1993 01:01:19 +00:00 discover.js
143 -rwx 17300 Mar 1 1993 01:01:19 +00:00 preflight.js
144 drwx 1408 Mar 1 1993 01:01:23 +00:00 help3
167 -rwx 2059 Mar 1 1993 01:01:24 +00:00 stylesheet.css
168 -rwx 471 Mar 1 1993 01:01:24 +00:00 homepage.htm
169 -rwx 28348 Mar 1 1993 01:01:24 +00:00 ajax.js
170 -rwx 29 Mar 1 1993 01:01:24 +00:00 port.js
171 -rwx 71429 Mar 1 1993 01:01:26 +00:00 xsetup.js
172 -rwx 425 Mar 1 1993 01:01:26 +00:00 reloadstatus.htm
173 -rwx 1616 Mar 1 1993 01:01:26 +00:00 layers.js
174 drwx 1088 Mar 1 1993 01:01:32 +00:00 in
216 -rwx 13756 Mar 1 1993 01:01:32 +00:00 forms.js
217 drwx 18240 Mar 1 1993 01:01:54 +00:00 images
503 -rwx 515 Mar 1 1993 01:01:54 +00:00 back.htm
504 -rwx 107031 Mar 1 1993 01:01:57 +00:00 xsetup.shtml
505 -rwx 564 Mar 1 1993 01:01:57 +00:00 upgradestatus.shtml
506 -rwx 25715 Mar 1 1993 01:01:57 +00:00 framework.js
507 -rwx 6490 Mar 1 1993 01:01:57 +00:00 reset.htm
508 -rwx 41660 Mar 1 1993 01:01:58 +00:00 fpv.js
509 -rwx 7179 Mar 1 1993 01:01:59 +00:00 softwareupgrade-top.js
510 -rwx 43289 Mar 1 1993 01:01:59 +00:00 portruntime.shtml
511 -rwx 18990 Mar 1 1993 01:01:59 +00:00 topbannernofpv.shtml
512 -rwx 21606 Mar 1 1993 01:02:00 +00:00 portstatistics.shtml
513 -rwx 313 Mar 1 1993 01:02:00 +00:00 empty.htm
At the same time I created a new user but still the problem
Bonjour,
quel système d'exploitation et quel navigateur utilisez-vous ? Le problème pourrait être lié à une version java obsolète.Le lien ci-dessous explique comment vérifier la version Java et mettre à jour si nécessaire...
https://linuxhint.com/check-update-java-version/
Windows 10 Java version 8 Update 341 build 1.8.0_341-b10
Bonjour,
si vous utilisez Firefox, essayez de changer la langue préférée en anglais (voir image jointe).
Settings --> General
I always tried the same trouble
