Problem with 2821 saving configuration
Aaron D
I'm having a very frustrating issue with a 2821 router. Its configured with zone-based firewall, URL filtering, ssl vpn...etc..Very long configuration. Problem is, it no longer will allow me to save the configuration. I tried write erase, erase nvram:, erase nvram:startup-config and it won't get rid of the old startup configuration. I tried service compress-config manually deleting all references to a startup-config, but it will never disappear, and it will no longer update. Configuration register is set to 0x2102.
I tried boot config to a config file in flash but this won't stay in the config due to the issue above.
Any help much appreciated.
thanks-
Aaron
9 Replies 9
burleyman
Level 8
Level 8
What IOS are you running?
Also what error are you getting when you run  write mem
Mike
IOS is below, I'm getting no error when I do a write mem or copy run start. On a copy run start it gives me the [s
tarup-config] prompt
Aaron
Mark Rigby
Can you post the output from the following please:
  • Show Flash:
  • Show Ver:
Also run the command
show file descriptor
Do you see 128 entries?
I think this is the same bug we just came across.
Mike
Aaron D
Thanks for the quick replies, here is the output from your queries:
login as:
Attention! This is a private system. All activities are logged and can be used for disciplinary action.Using keyboard-interactive authentication.
Password:
#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(24)T2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 19-Oct-09 17:38 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
uptime is 7 hours, 24 minutes
System restarted at 01:41:13 CST Tue Mar 2 2010
System image file is "flash:c2800nm-advsecurityk9-mz.124-24.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. 2821 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
If
Cisco
#dir all
#dir all-filesystems
Directory of archive:/
No files in directory
No space information available
Directory of system:/
    2  -r--           0                      default-running-config
   17  dr-x           0                      fpm
    4  dr-x           0                      memory
    1  -rw-       29219                      running-config
    3  dr-x           0                      vfiles
Directory of tmpsys:/
    6  drw-           0                      eem_lib_system
    5  drw-           0                      eem_lib_user
   17  -rw-           0                      eem_pnt_0
   19  -rw-           0                      eem_pnt_1
   37  -rw-           0                      eem_pnt_10
   39  -rw-           0                      eem_pnt_11
   41  -rw-           0                      eem_pnt_12
   43  -rw-           0                      eem_pnt_13
   45  -rw-           0                      eem_pnt_14
   47  -rw-           0                      eem_pnt_15
   21  -rw-           0                      eem_pnt_2
   23  -rw-           0                      eem_pnt_3
   25  -rw-           0                      eem_pnt_4
   27  -rw-           0                      eem_pnt_5
   29  -rw-           0                      eem_pnt_6
   31  -rw-           0                      eem_pnt_7
   33  -rw-           0                      eem_pnt_8
   35  -rw-           0                      eem_pnt_9
    4  drw-           0                      eem_policy
    8  drw-           0                      eem_pub
   16  -rw-           0                      eem_rpc_0
   18  -rw-           0                      eem_rpc_1
   36  -rw-           0                      eem_rpc_10
   38  -rw-           0                      eem_rpc_11
   40  -rw-           0                      eem_rpc_12
   42  -rw-           0                      eem_rpc_13
   44  -rw-           0                      eem_rpc_14
   46  -rw-           0                      eem_rpc_15
   20  -rw-           0                      eem_rpc_2
   22  -rw-           0                      eem_rpc_3
   24  -rw-           0                      eem_rpc_4
   26  -rw-           0                      eem_rpc_5
   28  -rw-           0                      eem_rpc_6
   30  -rw-           0                      eem_rpc_7
   32  -rw-           0                      eem_rpc_8
   34  -rw-           0                      eem_rpc_9
    7  drw-           0                      eem_temp
    1  dr-x           0                      lib
Directory of flash:/
    1  -rw-    38745460   Mar 2 2010 20:42:16 -06:00  c2800nm-advsecurityk9-mz.124-24.T2.bin
    2  -rw-        2751  Sep 29 2008 03:13:44 -06:00  sdmconfig-28xx.cfg
    3  -rw-      931840  Sep 29 2008 03:14:02 -06:00  es.tar
    4  -rw-     1505280  Sep 29 2008 03:14:24 -06:00  common.tar
    5  -rw-        1038  Sep 29 2008 03:14:40 -06:00  home.shtml
    6  -rw-      112640  Sep 29 2008 03:14:58 -06:00  home.tar
    7  -rw-      527849  Sep 29 2008 03:15:18 -06:00  128MB.sdf
    8  -rw-     1697952  Sep 29 2008 03:15:50 -06:00  securedesktop-ios-3.1.1.45-k9.pkg
    9  -rw-      415956  Sep 29 2008 03:16:10 -06:00  sslclient-win-1.1.4.176.pkg
   10  -rw-      196026   Feb 9 2009 15:21:48 -06:00  crashinfo_20090209-212148
   11  -rw-      230851  May 16 2009 18:20:42 -06:00  crashinfo_20090516-002042
   12  -rw-      199003   Aug 1 2009 17:14:16 -06:00  crashinfo_20090801-231416
   13  -rw-       21913   Mar 2 2010 20:09:02 -06:00  config.cfg
   14  -rw-     3795649  Feb 28 2010 12:38:08 -06:00  anyconnect-dart-win-2.4.1012-k9.pkg
   15  drw-           0  Feb 28 2010 13:56:50 -06:00  webvpn
   17  -rw-       21941   Mar 2 2010 01:38:52 -06:00  startup-config
64016384 bytes total (11780096 bytes free)
Directory of nvram:/
  213  -rw-       21787                      startup-config
  214  ----        3845                      private-config
  215  -rw-       21787                      underlying-config
    1  -rw-           0                      ifIndex-table
    2  -rw-         804                      EquifaxSecur#F4F4CA.cer
    3  -rw-        2945                      cwmp_inventory
    6  ----          36                      persistent-data
    7  -rw-        1194                      UTN-USERFirs#2525CA.cer
    9  -rw-         675                      wtsuiciscoco#0CA.cer
   10  -rw-         592                      IOS-Self-Sig#1.cer
245752 bytes total (209828 bytes free)
#       sh flash
-#- --length-- -----date/time------ path
1     38745460 Mar 03 2010 02:42:16 c2800nm-advsecurityk9-mz.124-24.T2.bin
2         2751 Sep 29 2008 09:13:44 sdmconfig-28xx.cfg
3       931840 Sep 29 2008 09:14:02 es.tar
4      1505280 Sep 29 2008 09:14:24 common.tar
5         1038 Sep 29 2008 09:14:40 home.shtml
6       112640 Sep 29 2008 09:14:58 home.tar
7       527849 Sep 29 2008 09:15:18 128MB.sdf
8      1697952 Sep 29 2008 09:15:50 securedesktop-ios-3.1.1.45-k9.pkg
9       415956 Sep 29 2008 09:16:10 sslclient-win-1.1.4.176.pkg
10      196026 Feb 09 2009 21:21:48 crashinfo_20090209-212148
11      230851 May 17 2009 00:20:42 crashinfo_20090516-002042
12      199003 Aug 01 2009 23:14:16 crashinfo_20090801-231416
13       21913 Mar 03 2010 02:09:02 config.cfg
14     3795649 Feb 28 2010 18:38:08 anyconnect-dart-win-2.4.1012-k9.pkg
15           0 Feb 28 2010 19:56:50 webvpn
16     3795649 Feb 28 2010 19:57:04 webvpn/svc_1.pkg
17       21941 Mar 02 2010 07:38:52 startup-config
11780096 bytes available (52236288 bytes used)
#sh file descriptors
File Descriptors:
   FD  Position  Open  PID  Path
    0         0  0001    3  lic0:trailprschk.prs
    1         0  0001    3  lic0:trailprs.prs
    2         0  0001    3  lic0:revocationprs.prs
    3         0  0001    3  lic0:trailprschk.bck
    4         0  0001    3  lic0:revocationchk.prs
    5         0  0001    3  lic0:revocationchk.bck
    6         0  0003    3  lic0:lservrc.pri
Aaron D
Also-size of running config:, notice startup-config hasn't saved since Dec 2009 argh-
Building configuration...
Current configuration : 29219 bytes
version 12.4
service timestamps log datetime localtime
service sequence-numbers
#sh start
Using 21787 out of 245752 bytes
! Last configuration change at 14:17:10 CST Mon Dec 28 2009 by
! NVRAM config last updated at 14:17:16 CST Mon Dec 28 2009 by !
version 12.4
burleyman
Level 8
Level 8
What is the output when you do a   write mem
Mike
#wr mem
[OK]
#copy run start
Destination filename [startup-config]?
[OK]
After looking at your outputs it is not the bug we had.
Mike
