Problem with 3750 switch
shahryarmunir
Community Member
All of a sudden my 3750 switch port LED's start blinking very quickly and the network is down. Please help me
7 Replies 7
michal.grzelak
Level 3
Level 3
That might be a lot of things, e.g. spanning-tree loop or DoS atack. Please conect via console to this switch and provide logs from that period. Network diagram also would be helpful.
Regards:
Michal
Hi Michal,
Plz tell me how to get logs
spremkumar
Level 11
Level 11
Did you try logging onto the console port of the switch ?
regds
Please tell me how to enable logging
Thanks\
When you're connected over serial:
in configure mode:
logging console debug
-> logging is enabled for console
When you're connected over ip:
in configure mode:
logging monitor debug
terminal monitor
-> logging is enabled for terminal
Proof logging preferences:
sh logging
Be careful with logging to console.
regards
Jens
CHN
Community Member
i think it was caused by broadcast stom.to check if span-loop occured.
