Problem with CS3020 Cisco Switches in HP C7000 enclosure.
kberry701
                   OK, I am no Cisco guru, and am really stuck here. This is probably not difficult, but I am perplexed at this point.
I have 5 ESX servers that are already fully configured, and were talking across my network earlier. The (2) switches in this enclosure were
manipulated and no longer seem to talk. Basically, just dealing with the first switch, and trying to get it working first. I'll just copy the config over when this one is fixed.
So, the first 16 ports on the switch are connected to the positions 1-16 in the enclosure, where blade servers would be. In this case, positions 1-5 are in use.
In the back of the enclosure, the switch has ports 0/17 - 24 for external connections. 2 ports are in use for a LACP uplink to the core switch. 2 ports  are in use for a LAPC uplink to external storage.
I can, from the core switch, pint this switch in the enclosure, and vice versa. I cannot however, from this switch in the enclosure ping any blade switches in the enclosure.
My servers are at 10.10.1.233 - 236
The enclosure's Cisco CS3020 switch is at 10.10.0.18      255.255.0.0
My core switch is 10.10.0.13      255.255.0.0
My config looks like this now:
version 12.2
no service pad
hostname BL465c_SW1
boot-start-marker
boot-end-marker
enable secret 5 $1$e1CS$aYLN09vAVG7LzaKQHseno0
enable password Seagate_2001
no aaa new-model
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
description HP CORE
switchport trunk allowed vlan 1-3,100
switchport mode trunk
interface Port-channel2
description ESXi VLAN trunk
switchport trunk allowed vlan 1-3,90,100
interface Port-channel5
description storage HP-SW1
switchport trunk allowed vlan 90
interface FastEthernet0
description ILO connection
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface GigabitEthernet0/1
switchport access vlan 3
switchport mode access
speed 1000
spanning-tree portfast
interface GigabitEthernet0/2
speed 1000
interface GigabitEthernet0/3
speed 1000
interface GigabitEthernet0/4
speed 1000
interface GigabitEthernet0/5
speed 1000
interface GigabitEthernet0/6
speed 1000
interface GigabitEthernet0/7
speed 1000
interface GigabitEthernet0/8
speed 1000
interface GigabitEthernet0/9
speed 1000
interface GigabitEthernet0/10
speed 1000
interface GigabitEthernet0/11
speed 1000
interface GigabitEthernet0/12
speed 1000
interface GigabitEthernet0/13
          speed 1000
interface GigabitEthernet0/14
speed 1000
interface GigabitEthernet0/15
speed 1000
interface GigabitEthernet0/16
speed 1000
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
description HP CORE
channel-protocol lacp
channel-group 1 mode active
spanning-tree portfast trunk
interface GigabitEthernet0/21
description Back to HP STORAGE
switchport access vlan 90
channel-group 5 mode active
interface GigabitEthernet0/22
description HP CORE
speed 1000
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface Vlan1
ip address 10.10.0.18 255.255.0.0
no ip route-cache
no ip mroute-cache
interface Vlan2
no ip address
no ip route-cache
no ip mroute-cache
interface Vlan3
no ip address
no ip route-cache
no ip mroute-cache
interface Vlan90
no ip address
no ip route-cache
no ip mroute-cache
ip default-gateway 10.10.0.1
ip classless
ip http server
ip http secure-server
snmp-server community public RO
line con 0
line vty 0 4
password xxxxx
login
line vty 5 15
password xxxxx
login
end
version 12.2
no service pad
hostname BL465c_SW1
boot-start-marker
boot-end-marker
enable password ^&%&^
no aaa new-model
ip subnet-zero
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1449868288
revocation-check none
rsakeypair TP-self-signed-1449868288
description HP CORE
no ip address
no ip route-cache
no ip mroute-cache
shutdown
speed 1000
speed 1000
speed 1000
speed 1000
speed 1000
speed 1000
speed 1000
speed 1000
speed 1000
speed 1000
speed 1000
speed 1000
         speed 1000
speed 1000
speed 1000
speed 1000
description HP CORE
description HP CORE
speed 1000
interface Vlan1
no ip route-cache
no ip mroute-cache
interface Vlan2
no ip address
no ip route-cache
no ip mroute-cache
interface Vlan3
no ip address
no ip route-cache
no ip mroute-cache
interface Vlan90
no ip address
no ip route-cache
no ip mroute-cache
ip classless
ip http server
line con 0
line vty 0 4
password xxxxx
login
line vty 5 15
password xxxxx
login
end
Also, those servers in the enclosure are esxi 4.1 hosts, and will each host vm's from  vlan 1, 2, 3. vmware vmotion is on vlan100. All storage is on vlan 90. So, essentially, each port (at least 1-5, currently) will need to talk to all of those vlans.
Can anyone advise?
rbplayerda
Looks like you have the config posted twice.
Anyway, you could set the ports to Trunk and tag the Virtual NICs with their respective VLAN.
