Problem with Etherchannel between 3548xl and 2960G
gkonheiser
Hi there
I have just set up an 2 port etherchannel  between my 3548XL and my 2960G, it all loks good but when I do a shut on int gi0/2 on the 3548XL the link goes down completly, should it not failover to the remaning link?  Here is my config:-
3548XL
interface GigabitEthernet0/1
port group 1
switchport mode trunk
interface GigabitEthernet0/2
port group 1
2960G
interface Port-channel1
interface GigabitEthernet0/6
channel-group 1 mode on
interface GigabitEthernet0/10
Thanks for any help
Antonio Knox
Level 7
Level 7
Working with 3500XL series can get a little tricky when it comes to etherchannels.  Make sure you:
!--- First, shut down the secondary ports involved in the channel
!--- and then enable them back when the configuration is complete on both switches.
See:
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094bc5.shtml#configs1
Yup tried that after doing the config, no change.
none of these ports are in a monitoring (SPAN) session, correct?
No?
