Problem with NAT configuration
domcia339
I've configured NAT, but it is not working.
Could you tell me what is wrong with my configuration?
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
ip name-server 8.8.8.8
no ipv6 cef
archive
log config
hidekeys
ip tcp synwait-time 5
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex half
interface FastEthernet1/0
ip address 194.169.1.1 255.255.255.0
ip nat inside
duplex half
interface FastEthernet2/0
ip address 194.169.2.1 255.255.255.0
ip nat inside
duplex half
router ospf 1
log-adjacency-changes
network 1.1.1.0 0.0.0.255 area 0
network 194.169.1.0 0.0.0.255 area 0
network 194.169.2.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 194.169.1.0 0.0.0.255
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Thank you,
Best Regards,
7 Replies 7
looks like your default route is missing, and the access list misses one subnet. Make sure the below is in your config:
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
access-list 1 permit 194.169.2.0 0.0.0.255
Thanks for your reply!
I've added these lines to my configuration, but nothing has changed.
NAT is still not working.
Command "show ip nat translations" show nothing.
Do you have any other idea, what should I do?
Thanks.
can you post the output of 'show ip int brief' ?
Also, can you ping 8.8.8.8 from the router ?
Yes, I can.
show ip int brief:
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            172.16.201.87   YES DHCP   up                     up
FastEthernet1/0            194.169.1.1      YES NVRAM  up                    up
FastEthernet2/0            194.169.2.1      YES NVRAM  up                    up
Loopback0                   1.1.1.1              YES NVRAM  up                    up
NVI0                            1.1.1.1               YES unset  up                       up
what does the rest of your topology look like, that is, is this a standalone router, or part of a larger network ?
Also, can your clients ping 172.16.201.87 ?
