Problem with router configuration, not sure where I'm going wrong
pjw17279
Hi there,
I'm just working my through some online lab activities with packet tracer and have gotten stuck on one activity. In this lab I'm basically troubleshooting a network and fixing errors, making sure it adheres to the IP addressing table and has specific switch port assignments.
So far I feel like I've fixed everything I can and addressed all issues on the interfaces yet I still don't understand why my router is not connecting... I feel like I'm being stupid or have forgotten something basic, it would be greatly appreciated if somebody could steer me in right direction!
I've attached the packet tracer file in the zip folder which has all my configurations so far and below is what shows on the router interface
R1#show interface
FastEthernet0/0 is administratively down, line protocol is down (disabled)
Hardware is Lance, address is 000a.41b1.c101 (bia 000a.41b1.c101)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Full-duplex, 100Mb/s, media type is RJ45
ARP type: ARPA, ARP Timeout 04:00:00,
Last input 00:00:08, output 00:00:05, output hang never
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: fifo
Output queue :0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
FastEthernet0/1 is administratively down, line protocol is down (disabled)
Hardware is Lance, address is 000a.41b1.c102 (bia 000a.41b1.c102)
FastEthernet0/1.1 is down, line protocol is down (disabled)
Hardware is PQUICC_FEC, address is 000a.41b1.c102 (bia 000a.41b1.c102)
Internet address is 192.168.1.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 11
FastEthernet0/1.10 is down, line protocol is down (disabled)
Internet address is 192.168.10.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 10
FastEthernet0/1.20 is down, line protocol is down (disabled)
Internet address is 192.168.99.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 20
Loopback0 is up, line protocol is up (connected)
Hardware is Loopback
Internet address is 209.165.200.225/27
MTU 1514 bytes, BW 8000000 Kbit, DLY 5000 usec,
Encapsulation LOOPBACK, loopback not set
Last input never, output never, output hang never
Output queue 0/0, 0 drops; input queue 0/75, 0 drops
Vlan1 is administratively down, line protocol is down
Hardware is CPU Interface, address is 00e0.f7d7.43cd (bia 00e0.f7d7.43cd)
MTU 1500 bytes, BW 100000 Kbit, DLY 1000000 usec,
Last input 21:40:21, output never, output hang never
Output queue: 0/40 (size/max)
1682 packets input, 530955 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
563859 packets output, 0 bytes, 0 underruns
0 output errors, 23 interface resets
2 Accepted Solutions
balaji.bandi
I am not a PT user. But looking at your output and image of IP address
this is admin down,
make sure interface up and running
config t
fas 0/1
no shut
check always, show ip interface brief to see all the interface up and running
BB
Harold Ritter
On top of what Balaji has already pointed out, I notice that S1 is connected to R1 port F0/0 and it should be connected to port f0/1 according to the addressing plan.
You will also need to change subnet 192.168.99.0/24 to 192.168.20.0/24 on both R1 and PC-B to conform to the addressing plan.
6 Replies 6
balaji.bandi
this is admin down,
config t
fas 0/1
no shut
BB
Brilliant thank you, I had completely forgotten my no shutdown commands (both on vlans and interfaces)! I've been staring at packet tracer too much today haha, much appreciated
Harold Ritter
Thanks so much for your time and response, all fixed now and I was making a completely novice error
have a look at the revised file...
pjw17279
Thank you so much for this reply and your help! I can't believe I had forgotten to issue my no shutdown command haha, thanks ever so much!
