Problem with RSPAN
ccomelli
Frequent Visitor
Frequent Visitor
Hi!
I have a problem with RSPAN. I have 2 CAT6500. I need to monitor ports on both 6500. The destinations are in both 6500 too. I configure the following monitor session on both 65000.
monitor session 1 source interface Gi6/28 - 31 , Gi6/34 - 35 , Gi6/37 - 39
monitor session 1 destination remote vlan 999
monitor session 2 destination interface Gi6/45
monitor session 2 destination interface Gi9/29
monitor session 2 destination interface Gi10/12
monitor session 2 source remote vlan 999
VLAN 999 is a remote span VLAN, so the traffic is sending to local ports and to the neighbor 6500.
The traffic is RTP. We use the SPAN to record VoIP calls.
When I reproduce the VoIP call, we detected lost of RTP traffic. The real call didn't have a problem, so i Guess that is a RSPAN problem.
I see 2 documents. One use the showed configuration. The other document said that this configuration didn't work.
+ Using RSPAN with VACLs for Granular Traffic Analysis
+ Catalyst Switched Port Analyzer (SPAN) Configuration Example (See the section Can a RSPAN Source Session and the Destination Session Exist on the Same Catalyst Switch? Page 37)
Which one is true?
Best regards!
Fabienne Stephanoff
Do you know what marking that traffic has?
I am not convinced this is a config issue or it would not work at all. It appears to be a qos related type issue.
Fabienne
LAN-Switching TAC
