Problem with Vlans comunication
manuelmejia
Hello i have a problem and the VLANS of the same router won't communicate between each other. I don't know What the problem is they also won't communicate between Routers but i belive that a VPN problem that i will try to solve later i just hope it isn't that whats causing the trouble....
@manuelmejia hi, you are using wrong default gateway IP inside pools. you need to configure router interface IP respective to each VLAN as a default gateway IP for relevant DHCP pools
EX.
default gateway IP for 172.17.0.0 pool needs to be 172.17.0.1 (not 172.16.0.1)
Good luck
KB
manuelmejia
For some reason it didn't upload the Proyect. here it is
EX.
Good luck
KB
