Problem with VPC between C9500 and N5K
mfilser
Hi all.
I have a problem between Nexus 5K and Catalyst 9500 (C9500-48Y4C / Stack Wise Virtual).
The VPC is reporting an error (vpc port channel mis-config due to vpc links in the 2 switches connected to different partners)
The N5K's were connected to a C6509-VSS-system and I've replaced it by C9500-Stack-Wise-Virtual.
Connected to the C6509, the VPC was working fine. But now I have an error.
It seems, the C9500 is reporting two different mac-adresses to the N5K's.
I've controlled the configuration, but I can't find any misconfiguration.
On N5K the configuration was not changed. On C9500 booth links are configured identical and bundeled into a port-channel.
Mode is configured as activ.
The solution about this issue I found in the Internet, is to shut/no shut the port-channel on C9500-site. But this is not an option,
because I can't interrupt the traffic to the server-farm behind the N5K's (live operation).
Is there a possibility to bring up the VPC without interrupting the connection?
I would be able to establish a second VPC between the Systems, but I'm not really familiar with Nexus. So I would need a "How-To" to configure it and step-by-step for a non-interrupting-operation.
If you need additional information, please let me know.
Hope, someone can help
Best regards
Markus
Here you will find some informations:
C9500# ==> Cisco IOS XE Software, Version 16.12.04
==> Model Number: C9500-48Y4C
C9500# sh run int po126
interface Port-channel126
description Uplink_DAC
switchport mode trunk
sh run int twe 1/0/43 (identical to 2/0/43)
interface TwentyFiveGigE1/0/43
channel-group 126 mode active
C9500# sh lacp 126 neigh
sh lacp 126 neigh
Flags: S - Device is requesting Slow LACPDUs
F - Device is requesting Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
Channel group 126 neighbors
LACP port Admin Oper Port Port
Port Flags Priority Dev ID Age key Key Number State
Twe1/0/43 SA 32768 0023.04ee.be65 28s 0x0 0x802B 0x12B 0x3D
Twe2/0/43 SP 0 0000.0000.0000 856328s 0x0 0x0 0x0 0x0
Nexus 5K 01 and Nexus 5K 02
Software
BIOS: version 2.1.7
Power Sequencer Firmware:
Module 1: v4.0
Module 1: v4.0
Fabric Power Sequencer Firmware: Module 1: version v4.0
Microcontroller Firmware: version v0.0.0.15
QSFP Microcontroller Firmware:
Module 1: v2.0.0.0
Module 1: v1.3.0.0
CXP Microcontroller Firmware:
Module not detected
kickstart: version 7.3(5)N1(1)
system: version 7.3(5)N1(1)
BIOS compile time: 06/16/2016
kickstart image file is: bootflash:///n6000-uk9-kickstart.7.3.5.N1.1.bin
kickstart compile time: 2/11/2019 2:00:00 [02/11/2019 16:36:57]
system image file is: bootflash:///n6000-uk9.7.3.5.N1.1.bin
system compile time: 2/11/2019 2:00:00 [02/11/2019 16:38:54]
Hardware
cisco Nexus 5672UP Chassis ("Nexus 5672UP Supervisor")
Intel(R) Xeon(R) CPU @ 1.80 with 8243276 kB of memory.
Processor Board ID FOC22362EVZ
Device name: xxxxxxxx
bootflash: 7208960 kB
Kernel uptime is 700 day(s), 22 hour(s), 47 minute(s), 22 second(s)
Last reset at 336703 usecs after Mon Jun 10 09:26:28 2019
Reason: Disruptive upgrade
System version: 7.3(3)N1(1)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s)
N5K_01# sh vpc brief
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 101
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 15
Peer Gateway : Enabled
Peer gateway excluded VLANs : -
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Operational Layer3 Peer-router : Enabled
Auto-recovery status : Enabled (timeout = 240 seconds)
vPC Peer-link status
id Port Status Active vlans
1 Po100 up 1-2,10,35,85,100,108,136,151,156,177-178,200,2061-
2062,3000,3004,3008,3099
vPC status
id Port Status Consistency Reason Active vlans
1 Po1 up success success 1-2,10,35,8
5,100,108,1
51,177-178,
200,2061-20
62
3 Po3 up success success 1-2,10,35,8
5,100,108,1
51,177-178,
200,2061-20
62
43 Po43 up success success 1-2,10,35,8
5,100,108,1
36,151,156,
177-178,200
,2061-20....
N5K_02# sh vpc brief
Legend:
vPC domain id : 101
vPC role : secondary
vPC status
5,100,108,1
51,177-178,
200,2061-20
62
5,100,108,1
51,177-178,
200,2061-20
62
43 Po43 down* failed vpc port channel -
partners
N5K_01 and N5K_02
sh run int po43
interface port-channel43
description Uplink_Core
switchport trunk allowed vlan 1-2,10,35,85,100,108,136,151,156,177-178,200,2061-2062,3000,30
04,3099
speed 10000
vpc 43
sh run int Eth1/43
interface Ethernet1/43
04,3099
channel-group 43 mode active
N5K_01# sh lacp port-channel
port-channel43
System Mac=0-3a-9c-26-47-c1
Local System Identifier=0x8000,0-3a-9c-26-47-c1
Admin key=0x802b
Operational key=0x802b
Partner System Identifier=0x8000,cc-7f-76-43-c0-c0
Operational key=0x7e
Max delay=0
Aggregate or individual=0
Member Port List=43
N5K_02# sh lacp port-channel ==> no information about lacp (because link Eth1/43 is suspended by vpc)
marce1000
 Ref : https://community.cisco.com/t5/server-networking/has-anybody-seen-this-vpc-error-on-the-5k/td-p/1417364
                      Check if the Resolving-reply of this thread can be applied to your case.
 M.
Hi.
Thx for the answer.
But it's not an option, because it will interrupt the traffic. And I'm searching for a solution without any cut ....
Best regards
Markus
 - Afraid it looks quite  indicative it may be required, for business-continuity launch case with TAC and state your business-needs on this matter.
 M.
