Problem with WS-6904-40G module and VSL link (VSS between two C6509-E)
ciscomagu
%VSLP-SW1-3-VSLP_LMP_FAIL_REASON: Te1/3/6: Link down
We have a problem with our WS-X6904-40G module and VSL links.
We have two Catalyst 6509-E with VSS configured. Our VSL links is:
On supervisor module:
Te1/5/4 – Te2/5/4
Te1/5/5 – Te2/5/5
WS-X6904-40G module:
Te1/3/6 – Te2/3/6
Suddenly the Te1/3/6 went down and the only log message we get is:
%VSLP-SW2_STBY-3-VSLP_LMP_FAIL_REASON: Te2/3/6: Timeout (60000msec) waiting for Hello packet from peer
What we have done is change 10 Gbit SFP module, fiber on both side and fiber between locations. Also change port but no change. There is no light on Te1/3/6 but there is orange light on Te2/3/6.
Little information about the environment:
Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.0(1)SY3, RELEASE SOFTWARE (fc2)
cisco WS-C6509-E (M8572) processor (revision ) with 1769472K/262144K bytes of memory.
CPU: MPC8572_E, Version: 2.2, (0x80E80022)
 CORE: E500, Version: 3.0, (0x80210030)
 CPU:1500MHz, CCB:600MHz, DDR:600MHz
 L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
85 Virtual Ethernet interfaces
150 Gigabit Ethernet interfaces
36 Ten Gigabit Ethernet interfaces
2543K bytes of non-volatile configuration memory.
Mod Ports Card Type                                                               Model
  1   24  CEF720 24 port 1000mb SFP                                     WS-X6824-SFP
  2   48  CEF720 48 port 10/100/1000mb Ethernet                WS-X6848-GE-TX
  3   20  DCEF2T 4 port 40GE / 16 port 10GE                         WS-X6904-40G
  5    5  Supervisor Engine 2T 10GE w/ CTS                            Acti VS-SUP2T-10G
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  acf2.c597.51b0 to acf2.c597.51c7   1.0   12.2(18r)S1  15.0(1)SY3   Ok
  2  001f.6ca4.f518 to 001f.6ca4.f547   1.0   12.2(18r)S1  15.0(1)SY3   Ok
  3  70ca.9b8e.d03c to 70ca.9b8e.d04f   1.0   12.2(50r)SYL 15.0(1)SY3   Ok
  5  c471.fe7d.35aa to c471.fe7d.35b1   1.4   12.2(50r)SYS 15.0(1)SY3   Ok
Mod  Sub-Module                  Model                                       Hw     Status
  1  Distributed Forwarding Card WS-F6K-DFC4-A                 1.0    Ok
  2  Distributed Forwarding Card WS-F6K-DFC4-A                 1.0    Ok
  3  Distributed Forwarding Card WS-F6K-DFC4-E                 1.2    Ok
  5  Policy Feature Card 4       VS-F6K-PFC4                            1.2    Ok
  5  CPU Daughterboard           VS-F6K-MSFC5                                       1.5    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  5  Pass
Hope for any help !!
Best Regards
Magnus
InayathUlla Sharieff
I found a bug.
But this needs some more investigation could you please log a tac case so that  we record these issues?
Thanks for your replay !!
I have logged a case to TAC, maybe you could tell me the Bug ID.
Best Regards
Magnus
