02-18-2014 07:39 PM - edited 03-07-2019 06:17 PM
Hi All Expert
I found problem about cisco 3845 with
Cisco IOS Software, 3800 Software (C3845-ADVSECURITYK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1).
Cisco 3845 (revision 1.0) with 1008639K/39936K bytes of memory.
When I facing the problem it's can use only one command, "show version". other command not use and a result stop not complete but Cisco 3845 still alive not hang. This case effect with trafic.
Any one found this case, please advice me.
02-18-2014 07:42 PM
Can you get to enable mode?
02-18-2014 07:45 PM
I can access to enable mode
02-18-2014 07:48 PM
If you are in enable mode, please post the output to the command "sh proc cpu sorted 5sec | ex 0.00".
02-18-2014 07:51 PM
Cisco3845#sh proc cpu sorted 5sec | ex 0.00
no output, no anythinng after put the command
02-18-2014 07:55 PM
Upgrade your IOS to something more recent.
02-18-2014 07:57 PM
which IOS version you recommend.
02-18-2014 08:14 PM
I do not know your network. So you'll need to decide.
02-18-2014 09:53 PM
Thank You Sir, I will find version that meet my requirement.
