Problems adding VLAN on a 3750 switch
I'm trying to add a new VLAN on a 3750 switch that already has two VLAN's setup. I'm using the following commands, but get the error at the bottom.
PELONSWT02(config-vlan)#name PRTRVLAN
PELONSWT02(config-vlan)#^Z
VLAN 1003 parent VLAN missing
APPLY VLAN changes failed.
I currently have the 3750 cluster set as a VTP server on V2.
If I 'sh vlan' on the switch I get the following:
PELONSWT02#sh vlan
VLAN Name Status Ports
1 default active Gi1/0/1, Gi1/0/2, Gi1/0/3
Gi1/0/4, Gi1/0/5, Gi1/0/6
Gi1/0/7, Gi1/0/8, Gi1/0/11
Gi1/0/14, Gi1/0/16, Gi1/0/18
Gi1/0/20, Gi1/0/21, Gi1/0/22
Gi1/0/24, Gi2/0/1, Gi2/0/2
Gi2/0/3, Gi2/0/4, Gi2/0/5
Gi2/0/6, Gi2/0/7, Gi2/0/8
Gi2/0/11, Gi2/0/14, Gi2/0/16
Gi2/0/18, Gi2/0/20, Gi2/0/21
Gi2/0/23, Gi2/0/24, Gi3/0/1
Gi3/0/2, Gi3/0/4, Gi3/0/8
Gi3/0/14, Gi3/0/16, Gi3/0/17
Gi3/0/18, Gi3/0/19, Gi3/0/20
Gi3/0/21, Gi3/0/23, Gi3/0/24
Gi4/0/1, Gi4/0/2, Gi4/0/3
Gi4/0/4, Gi4/0/5, Gi4/0/6
Gi4/0/7, Gi4/0/8, Gi4/0/9
Gi4/0/10, Gi4/0/11, Gi4/0/12
Gi4/0/13, Gi4/0/14, Gi4/0/15
Gi4/0/16, Gi4/0/17, Gi4/0/18
Gi4/0/19, Gi4/0/20, Gi4/0/21
Gi4/0/22, Gi4/0/23, Gi4/0/24
10 IPVoice active
1002 fddi-default act/unsup
1003 trcrf-default act/unsup
1004 fddinet-default act/unsup
1005 trbrf-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 trcrf 101003 4472 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trbrf 101005 4472 - - - ibm - 0 0
VLAN AREHops STEHops Backup CRF
1003 0 0 off
Remote SPAN VLANs
Primary Secondary Type Ports
PELONSWT02#
How do I resolve this without destroying the existing vlan setup?
6 Replies 6
Amit Singh
This error message indicates that one or more switches in the network do not support V2
mode.
A VTP version 2-capable network device can operate in the same VTP domain as a network
device running VTP version 1 provided VTP version 2 is disabled on the VTP version
2-capable network device (VTP version 2 is disabled by default).
Do not enable VTP version 2 on a network device unless all of the network devices in the
same VTP domain are version 2-capable. When you enable VTP version 2 on a network device,
all of the version 2-capable network devices in the domain enable VTP version 2.
VTP Configuration Guidelines and Restrictions:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/v
tp.htm#wp1029449
Please do "no vtp v2-mode" under "config t" mode and then create the vlan.Basically idea is to configure all the switch to V2 mode if they support it or change the VTP mode to V1 as few of the switches donot support it.
HTH,Please rate if it does.
-amit singh
If I set to VTP mode1, will it have any knock on effect to my existing prod network?
I've checked all the network devices in the community and they all appear to be VTP2... Am I right in saying that I only need VTP2 for token ring?
mohammedmahmoud
Level 11
Level 11
Hi there,
What is the VLAN number that you are trying to add.
BR,
Mohammed Mahmoud.
Friend,
I think you are trying to add a VLAN with a VLAN ID of 1003.
You cannot use VLANs from 1001 - 1005. These are reserved vlans
Try configuring a different vlan number and check
HTH, rate if it does
Narayan
I'm trying to configure VLAN's 20, 30 and 40...
Please do as suggested in my earlier post and let us know if that works.
-amit singh
