Problems configuring voice vlan on switch SG350
Jhony.Da
Can anyone help me with the vlan voice commands for the SG350?
It turns out that I created a data vlan and a voice vlan, the problem is that when executing the voice vlan commands it doesn't take them and I searched the Internet and I think the commands are correct, but I may be missing some, so I ask for help if you can give me a hand.
The commands I have are the following:
int g0 / 2
  switchport access vlan 3
  switchport trunk native vlan 3
  switchport mode trunk
  switchport voice vlan 12 ---> this command doesn't work for me
  spanning-tree portfast
luis_cordova
Hi @Jhony.Da ,
Try leaving your interface like this:
int g0 / 2
  switchport access vlan 3 <-- data vlan
  switchport voice vlan 12 <-- voice vlan
