Problems in trunking with HWIC-4ESW on cisco 1921
tarik.cisco
Hello !
We have been facing a problem at my company ! We have a Cisco Router 1921 with one HWIC-4ESW in trunking with a RuggedCom switch RSG2100.
When I use the GigabitEthernet port to make a trunk, I create 2 sub-interfaces (one for each Vlan) and configure the Port on Switch as Trunk, the inter-VLan routing works with no problem.
But now I need to use this configuration using the HWIC-4ESW on Router, and I can't do this work. I try creat interface Vlan for each vlan, and try creating the VLans at Router Vlans database, but no way. At router I enter in interface and try to do the switchport trunk command to add a Vlan, but doesn't work.
Can anyone please do a little help to me ?
Thanks !
  To me it looks like you have mismatched native vlans on each side , vlan 1  on one side and vlan 30 on the other. Trunking setup must match on both sides.
glen.grant
Sample . Native vlans must match on each device. Cant help you with the non cisco device.
router# vlan database
enter
vlan 2 , enter
vlan 3 ,enter
exit
SUMMARY STEPS
1.                           enable
2.                           configure                                   terminal
3.    interface fastethernet interface-id
4.                           shutdown
5.    switchport mode trunk
6.    switchport  trunk native vlan vlan-number
7.    switchport trunk allowed vlan 2,3
8.                           no             shutdown
9.                           end
router# conf t
interf vlan 2
ip address 192.168.2.254 255.255.255.0
no shut
interf vlan 3
ip address 192.168.3.254 255.255.255.0
no shut
write mem
Ok Now it's working !
But now other problem appear !
The trunk (fast 0/0/1) with my ruggedcom network works ok, intervlan routing is working and so.  So now I link other port in trunk at same interface ( fast 0/0/3 ) with another swicth from 3com. When I plug the 3com cable cord, the  int fast 0/0/1 goes down and I receive the follow message in debug:
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/3, changed state to down
%LINK-3-UPDOWN: Interface FastEthernet0/0/3, changed state to down
dot1x-registry:dot1x_switch_port_linkcomingup invoked on interface Fa0/0/3
dot1x-registry:** dot1x_switch_vp_statechange:
dot1x-ev:vlan 1 vp is added on the interface FastEthernet0/0/3
dot1x-ev:vlan 30 vp is added on the interface FastEthernet0/0/3
dot1x-ev:vlan 40 vp is added on the interface FastEthernet0/0/3
%DTP-5-TRUNKPORTON: Port Fa0/0/3 has become dot1q trunk
%LINK-3-UPDOWN: Interface FastEthernet0/0/3, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/3, changed state to up
%SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking FastEthernet0/0/1 on VLAN1. Port consistency restored.
%SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking FastEthernet0/0/1 on VLAN30. Port consistency restored. PVST+:Inconsistency timer expired. inconsistency 0
                 cleared for FastEthernet0/0/1
%SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan id 1 on FastEthernet0/0/1 VLAN30.
%SPANTREE-2-BLOCK_PVID_PEER: Blocking FastEthernet0/0/1 on VLAN1. Inconsistent peer vlan.
%SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/0/1 on VLAN30. Inconsistent local vlan.
I put attached my router configuration and  topology layout for analisys.
What I'm doing wrong ?thanks
Thanks my man, You was very helpfull and I solve my problems.
If came to Brazil email me I pay the beer !
Thanks !!!!!!!
