Problems Upgrading C3850 IOS
mariusS
Visitor
Hello everyone,
i can‘t find a post about my topic that could help me.
I wanted to upgrade my Catalyst 3850 from the IOS Version cat3k_caa-universal9.16.12.09.SPA.bin to the
cat3k_caa-universal9.16.12.10a.SPA.bin
after issuing the boot system flash:(new IOS) command and reloading the switch, the switch starts with the ROMMON mode.
After trying to boot manually, the switch tells me that it‘s an invalid image.
I tried to load the older IOS version manually but then it kept saying: Not enough memory.
The same thing happens when I try to boot from my USB.
Thanks for reading. I hope that someone can give me other Ideas to try before I do an emergency install.
mariusS
Visitor
I was able to solve the problem.
I fixed it by simply changing the BOOT Var back to the old version. It took a while because I had to reload the switch a couple of times before the switch actually wanted to take the old file (had to restart it about three times).
Thanks for the nice and quick answers.
balaji.bandi
Did you deleted old .bin file from switch ?
If not you can still boot from that image when you are in ROMMON
or you have copy of OLD .BIN file copy to USB - make USB is recognised and FAT format and boot - before you upgrade to new version.
1. Verify that the flashdrive is recognized and the .bin file exists
switch: dir usbflash0:     or you can also do dir flash:
Directory of usbflash0:/
-rw- xxxx cat3k_caa-universal9.16.12.09.SPA.bin
2. Boot to the USB image
switch: boot usbflash0:cat3k_caa-universal9.16.12.09.SPA.bin
Once the switch booted as expected post below output :
show boot
show version
Upgrade to new image - use break key to get in ROMMON and boot with new image and see if that work.
-rw- xxxx cat3k_caa-universal9.16.12.10a.SPA.bin
switch: boot usbflash0:cat3k_caa-universal9.16.12.10a.SPA.bin
then copy to Flash: check and boot variable
Note : we always suggest to go to Install mode.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/system_management/configuration_guide/b_sm_3se_3850_cg/b_sm_3se_3850_cg_chapter_010100.html
BB
Leo Laohoo
If the switch is still in ROMMON, post the complete output to the following commands:
dir
set
mariusS
Visitor
I forgot to mention,
i repeated the whole upgrading process and it worked without any problems the second time.
