Problems with PXE boot for clients
calagg001
I have an environment where I have clients on av VLAN connected to a Cisco 2960X (WS-C2960X-48LPD-L ) with layer 3 configuration. The clients do a PXE boot to get configuration. The thing is that this does not work on all switches. The switches have the exact same configuration, the only thing that differs is Hardware Board Revision Number. (That I can find..) The ones that works has 0x05 and the ones that doesn´t work has 0x12. The PXE server is connected on a different VLAN in the same switch.
I have configured spanning-tree portfast on the interfaces. I have ip-helper on the VLAN. The PXE server is also the DHCP server.
Any suggestions?
Carina
0 Replies 0
