promiscous trunk port on 3750
yoguz
Hi there,
Is there a way to configure promiscous trunk port on Catalyst 3750 switch?
I couldn't find "switchport mode private-vlan trunk promiscous" command in my 3750. It has only "switchport mode private-vlan promiscous" and "switchport mode private-vlan host".
IOS is (C3750-IPBASEK9-M), Version 12.2(50)SE.
yasemin
8 Replies 8
Reza Sharifi
Hello Yasemin,
A promiscuous port belongs to the primary VLAN and can communicate with all interfaces, including the community and isolated host ports that belong to the secondary VLANs associated with the primary VLAN.
Have a look at 3750 config guide below:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swpvlan.html
Reza
Thanks for your message Reza. I know the functionality of primary VLAN. But I want the same port to be Promiscous port and trunk at the same time. Because my gateway for all of my VLANs is connected to that trunk port. On the other hand one of the VLANs is primary vlan.
I checked most of the documentation, it seems that, Catalyst 4500 ans Nexus has this functionality, but I'm not sure if 3750 can do.
Any new idea?
yasemin
Hello Yasemin,
I tried it on a 3750-E running 122-52.SE. It is either or, not both at the same time.
Here is the config before "witchport mode private-vlan promiscuous"
Switch(config-if)#do sh run int gi2/0/1
Building configuration...
Current configuration : 99 bytes
interface GigabitEthernet2/0/1
switchport mode trunk
end
Switch(config-if)#
And here is the config after I add the command
Switch(config-if)#switchport mode private-vlan promiscuous
Current configuration : 118 bytes
end
Switch(config-if)#
Reza
Hi Reza,
Yes I have the same result. But I 'm wondering if it is related with IOS or chassis. I mean is it possible to have this feauter/parameter with an other IOS version of 3750 or it's impossible.
Nexus 1000V and Cat 4500 has the "switchport mode private-vlan trunk " command, why not 3750?
yasemin
jroussy
I have the same problem, do someone know the answer?
SDaniels1
I too want to do this (my plan was to trunk 'DMZ' interfaces from an AS
A down to a 3750 and then do PVlans).
I soon ran into the issue of how can it be a trunk and a PV-promiscuous at the same time.
googling I found the switchport mode private-vlan trunk
command and like you saw that it only seems to apply to the 4500 (I didn't spot Nexus
as you have).
I would like to think that Cisco will add this feature into IOS updates for some IPBase
models lower down as PVlans without being able to do a trunked uplink really
takes away from the usefulness of them (IMHO).
You (we) could of course bodge this by trunking to a (another) switch and then doing an access
uplinks down to the 3750, but this is not ideal as its wasting ports on the 3750.
Oh well ..........
Zizhen Gao
Yasemin,
Unfortunately this is not supported on the 3750. It's currently a hardware limitation on the platform.
zz
An possible workarond that I've used in the same senarion is to use VACL instead.
It's a bit more config, and it's more troublesome to maintain.
So instead of using private VLAN's I use the following config:
(Assuming VLAN 100, Network 192.168.1.0/24 and ASA IP 192.168.1.1)
vlan 100
name Simulated_PVLAN
ip access-list extended ACL_VACL_100
permit ip 192.168.1.0 0.0.0.255 host 192.168.1.1
permit ip host 192.168.1.1 192.168.1.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 any
permit ip any 192.168.1.0 0.0.0.255
vlan access-map VACL_100 10
action forward
match ip address ACL_VACL_100
vlan filter VACL_100 vlan-list 100
This will let the hosts on the vlan speak to the ASA, and allow them to send traffic out to the outside, but not let them speak to each other.
Would have been a lot easier with an "switchport type private-vlan trunk promiscous" though...
