Vlan ACL Issue
snarayanaraju
Level 7
Level 7
Hi Experts,
I request your mind share & help. I am trying to configure VACL in 3750X. The configuration is below:
GOAL:
Block tcp 445 access between host 192.168.16.17 & 192.168.16.18. Whereas both the host should be able to access Internet (80,443,dns) allowed.
PROBLEM:
When i apply VLAN FILTER, all communication is blocked. I am not able to get Internet as well.
When i add permit ip any any in ACL entry  ALLOW-INET it is working, but again all traffic is allowed.
CONFIGURATION:
vlan access-map TEST 1
action forward
match ip address ALLOW-INET
vlan access-map TEST 2
action forward
match ip address BLOCK-445
vlan filter TEST vlan-list 16
Extended IP access list ALLOW-INET
    10 permit tcp host 192.168.16.18 any eq www
    30 permit tcp host 192.168.16.18 any eq 443
    40 permit udp host 192.168.16.18 any eq domain
    50 permit tcp host 192.168.16.17 any eq www
    60 permit tcp host 192.168.16.17 any eq 443
    70 permit udp host 192.168.16.17 any eq domain
Extended IP access list BLOCK-445
    20 deny tcp host 192.168.16.17 host 192.168.16.18 eq 445
    30 permit icmp host 192.168.16.17 host 192.168.16.18
Please help me where i am going wrong?
regards,
sathya
snarayanaraju
Level 7
Level 7
hi Friends,
I solved with myself. It is the ACL rule issue only. After established keyword, i am not to achieve the result
thanks
sathya
Hi Sathya,
I am also facing same issue, could u kindly share the configuration file...
Reg
Sashi
HI,
only for blocking 445 port from one ip to another u can simply acheive this by configurign the following,
access-list 100 permit tcp host 192.168.16.17 host 192.168.16.18 eq 445
vlan access-map FILTER445 10
action drop
match ip address 100
vlan access-map FILTER445 20 (to permit everything else)
action forward
vlan filter FILTER445 vlan-list 16
