Proper Cabling for a 2 3750-x switch Stack
healthtrans_2
Community Member
I have been looking at the Cisco Hardware docs and I can't find anything on the proper way to setup a 2 switch stack for Stackwise redundancy and Stackpower redundancy. Everything details 3 or more switches. Does anyone have some insight?
Bradford Chatterjee
Community Member
You just connect stack port 1 on the first switch to stack port 2 on the second and vice versa for both power and stackwise. The stackwise cables end up looking crossed over each other.
6 Replies 6
Bradford Chatterjee
Community Member
Thanks Bradford. That was what I was thinking but just trying to make sure I am following recommended setup. Appreciate the confirmation!
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Crossovers (sw1 port 1 to sw2 port 2 and sw 1 port 2 to sw 2 port 1) are probably more common, but at least for StackWise, it will also work sw 1 port 1 to sw 2 port 1 and sw 1 port 2 to sw 2 port 2.  I think StackPower doesn't really care either, as long as you complete one or both rings.
BTW, StackPower has limitations to how much amperage can flow through the power cables.  You need to take into account maximum power draw per switch and where you place power supplies.  This gets a little tricky when you consider a power supply failure.
Hi Healthtrans_2
Can you please tell me one thing
Is it safe to plug the power stacking cables while the stack switches are power on?
What is the recommended way?
Your reply will be highly appreciated.
Best Regards
Hi Bradford
Is it safe to plug the power satcking cables while the stack switches are power on?
What is the recomended way?
Best Regards
tariq-rashid
Visitor
I just found this. Is the same for 2 2960-s switches?
